after routing - the "fuzzies"! - Router Forums
post #1 of 10 (permalink) Old 09-16-2014, 02:30 PM Thread Starter
First Name: bob
Default after routing - the "fuzzies"!
Practicing printing my name with the router.
The dig is fuzzy on one side, clean on the other.
Is there a way of correcting this, or cleaning it
out manually?
rsauve is offline
post #2 of 10 (permalink) Old 09-16-2014, 06:34 PM
Fuzzies can be caused by dull bits, dirty bits, poor quality bits, and when going cross grain.
post #3 of 10 (permalink) Old 09-16-2014, 07:50 PM
First Name: Earl
Hey Bob, that's better free-hand than i think i could do. I see the fuzzies are all on one side of the cut, but not on the other. It also appears that your bit diameter is the same as your letter width. My conclusion from that is that one side of the cut is going the right direction (bit rotation cutting into the wood as you move the router), while the other side of the cut ends up being a climb cut (bit's cutting edge pushing away from the cut).
If that is the correct assumption, the solutions may include:
Use a smaller bit, and make the cut on the outside in one direction, then make the inside cut going the other direction so that your bit's cutting edge is always turning into the cut.
or
Use a small diameter bit to outline the letters (clockwise on the inside, counter clockwise on the outside), then use a wider straight bit to clean out the center.
Hope that makes sense. This article may be clearer: With a Router, You Need Direction
earl
greenacres2 is offline
post #4 of 10 (permalink) Old 09-17-2014, 12:59 PM
RainMan 2.0's Avatar
I've never seen tear out like this . Makes me wonder if the bits to dull, or the woods wet possibly?
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 10 (permalink) Old 09-17-2014, 01:53 PM
First Name: Phillip
I agree with Earl's assessment. Could also be a dull bit. You can fix this, depending on the thickness of the displaced fibers, by running some fine sand paper along the fuzzy edge.
To change the world, change your mind.
phillipdanbury is offline
post #6 of 10 (permalink) Old 09-18-2014, 09:59 AM
First Name: mary
we sometimes get this type of fuzzys on the CNC depending on the type of wood used. I use the drimmel with a sanding mop to clean them up, it is easier then hand sanding. Hope this helps
marecat3 is offline
post #7 of 10 (permalink) Old 09-18-2014, 12:44 PM
First Name: Brad
I agree with greenacres2. Change in direction to the grain.
If you would like to alleviate this problem, use a down cut spiral bit for this kind of work if you can. Leaves a clean edge on the top and leaves a very flat bottom. Only disadvantage is that it leaves the shaving in the groove without good dust collection. That is the trade off.
Just a suggestion. Always be aware which direction you are routing in and plan your cuts accordingly.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #8 of 10 (permalink) Old 09-18-2014, 08:36 PM
First Name: Earl
That's much better than my solutions Brad. I guess if i owned any spiral bits (up, down or compression), i might have had a different solution. Assuming i remembered i had those bits!!
Who was it that said "if the only tool you have is a hammer, every problem looks like a nail"? Somebody on here has that as a sig line!!
earl
post #9 of 10 (permalink) Old 09-18-2014, 09:36 PM
First Name: Brad
earl
It is hard for me to remember what bits I have, as well. I do know they are all sharp because I rarely use the same one twice. It seems I am buying a new one(s) every time I start a project.
post #10 of 10 (permalink) Old 09-23-2014, 10:31 AM Thread Starter
First Name: bob
Thank you all for you replies. I will try your suggestions.
rsauve is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 07:31 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
JIGS CAN MAKE ROUTING SAFER!! (lesson learned for a newbie) metzgeri Jigs and Fixtures 44 01-25-2011 11:00 AM
