Z-Axis Manual Reset - Router Forums
post #1 of 2 (permalink) Old 09-25-2014, 06:33 AM Thread Starter
First Name: Mallory
Default Z-Axis Manual Reset
We have had to reset our Z-Axis manually several times now. I understand we need to set the Z limit per job depending on switching up the materials, however, once a week or so after turning on and homing the CNC Router the Z-Axis reading is way off.
It is not a huge deal to have to reset it manually, however, I was told that this should only have to be done every 6 months or so. I am worried there is a problem within the computer itself, or perhaps a sensor. Any advice?
mlepisto2 is offline
post #2 of 2 (permalink) Old 11-16-2014, 03:04 PM
First Name: Alan
Is your program stand alone or run thru Windows? Windows has a problem with timing thru the parallel port and it shows up especially as the machine ages and doesn't put out a full 5 volts to the port. I'm not sure why but the problem always shows up on the z axis first. Eighty percent of the mills I repaired using Mach3 controls were fixed by replacing the computer or switching over to linuxcnc.
ve3sqb is offline
Instruction Manual wayoutwest General Routing 5 05-25-2016 08:11 AM
looking for manual for model #171254230 Bgothard Tools and Woodworking 0 06-05-2014 05:07 PM
V25 : Setting up a 4 axis cnc router ( B Axis ) on the Z aldepoalo CNC Routing 0 05-23-2013 11:56 AM
BobCAD CAM V25 4th Axis Standard aldepoalo CNC Routing 0 09-20-2012 05:10 PM
How to add a Manual Mark Power Tool Manuals 0 04-01-2010 07:00 PM
