Router base scratching laminate - Router Forums
post #1 of 12 (permalink) Old 09-28-2014, 12:34 AM Thread Starter
mikeoleary's Avatar
Country: Thailand
Default Router base scratching laminate
I am using a small Makita handheld router to trim excess .8mm laminate from the edges of a piece of plywood. The polycarbonate base of the router left small but noticable scratches in the matte laminate.
Is there a way to make a softer non scratching router base, or modify the one I already have?
mikeoleary is offline
post #2 of 12 (permalink) Old 09-28-2014, 01:06 AM
MAFoElffen's Avatar
What we usually do for routers and skill saws, when we do not want to leave marks is put some blue masking tape on the bases. Cheap and protects from leaving marks.
MAFoElffen is offline
post #3 of 12 (permalink) Old 09-28-2014, 07:57 AM
First Name: Jake
I use masking tape too but it's green..
Jakexp is offline
post #4 of 12 (permalink) Old 09-28-2014, 07:59 AM
CharleyL's Avatar
First Name: Charley
I also use masking tape, usually the blue type.
Charley
Central North Carolina
CharleyL is offline
post #5 of 12 (permalink) Old 09-28-2014, 08:05 AM
Country: South Africa
Try giving the base a good polish (car or floor polish) and buff it well with a soft cloth. Works for me.
splinterz is offline
post #6 of 12 (permalink) Old 09-28-2014, 08:24 AM
Originally Posted by mikeoleary View Post
I am using a small Makita hand held router to trim excess .8mm laminate from the edges of a piece of plywood. The polycarbonate base of the router left small but noticeable scratches in the matte laminate.
replace the base if it's scratched...
it's the scratches in it that are giving you issues...
the router's base is harder than the laminate...
Fume the old base w/ MEC...
you do this at your own risk of death..
furniture paste wax the new base...
apply a film of HDPE or HMW-HDPE to the base...
but this is what I think is really happening..
or it's the particles/cut dust from the laminate acting as an abrasive...
make a masking tape shield between the laminate and router...
put the tape on the laminate and let the router ride on the tape...
get some dust collection going too...
Buy Slick Strips, 3" Width at Woodcraft.com
post #7 of 12 (permalink) Old 09-28-2014, 08:40 AM
Garyk's Avatar
First Name: Gary
The pros use a thin layer of oil for the router base to glide on then just wipe it off. Use something light like machine oil. Paste wax would probably work too. Maybe WD-40 but I haven't tried that yet.
Garyk is offline
post #8 of 12 (permalink) Old 09-28-2014, 08:58 AM
not all of them...
that's a simple shortcut that can have side effects...
what happens when the oil penetrates/stains the laminates end grain if the laminate is other than HPG???
and the issue of the dust still remains..
post #9 of 12 (permalink) Old 09-28-2014, 09:32 AM
Honored Member
First Name: pat
Stick has it. But I would not scrap the scratchy subbase; I'd sand out the defects. It's usually the edge of the plate, secondarily, the subbase surface.
With abrasive glued to granite or glass, wet with mineral spirits.
Then sand until smooth to the touch. Do the edge of the plate with steel wool.
Wax the surface of the plate regularly. Friction is your enemy here.
And if you can remove the static charge on the plate you'll be ahead too.
Subbase selection.
Quillman is offline
post #10 of 12 (permalink) Old 09-28-2014, 11:52 AM
I would also try sanding the plate smooth again and check to make sure there are no burrs on the screw heads that hold the plates on. 600 grit wet or dry silicon carbide sandpaper is commonly available and it should be fine enough.
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Bosch 1617 router base problem bill kay General Routing 35 05-30-2016 08:39 AM
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Question about plunge base on Ridgid router Sawatzky General Routing 12 01-01-2011 11:44 PM
Moving Sub Base to Another Router don1 Portable Routing 8 01-25-2010 09:47 AM
