Options for busted Craftsman router - Router Forums
post #1 of 16 (permalink) Old 10-06-2014, 01:36 PM Thread Starter
First Name: Patrick
Default Options for busted Craftsman router
I have a Craftsman router (model number 315.175340) that I was using with a router wing extension on my table saw. One of the brushes cracked and I have to decide what to do with the router. Some options and considerations:
- The router basically cost me $10-$20 as an add-on when I purchased the (used) table saw, so I'm not heavily invested in it.
- It was mounted with a plunge base and came with some random bits and other extra parts. I mention this because it didn't come with the fixed base that I think would work better under the table.
- Some quick web browsing suggests Sears no longer stocks the brushes and finding a fixed base will require some luck on eBay or Craigslist.
- Given all of the above, I'm leaning toward letting go of the Craftsman and getting something with a fixed base and lots of extra brushes.
- Before I do that I thought I'd check with you all to see if there are solutions I haven't considered.
- Finally, if I do let go of the Craftsman, is there any 'second life' for router motors? It just seems wasteful to toss it in the trash.
Thank you!
OriginalPatrick is offline
post #2 of 16 (permalink) Old 10-06-2014, 01:56 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the forum.
Call this people maybe they can help you
MOTOR AND TOOL BRUSHES with eared cap
Thank You John
Semipro is offline
post #3 of 16 (permalink) Old 10-06-2014, 05:11 PM
old55's Avatar
First Name: Ross
Welcome to the forum Patrick.
Ross,
old55 is offline
post #4 of 16 (permalink) Old 10-06-2014, 06:43 PM
MikeMa's Avatar
For what its worth, you don't have much invested in it, I don't know that I would put any more in it. Do yourself a favor and treat yourself to a new router.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #5 of 16 (permalink) Old 10-06-2014, 07:10 PM
Knothead47's Avatar
New router is the cure for the problem.
John T.
Knothead47 is offline
post #6 of 16 (permalink) Old 10-06-2014, 07:13 PM
Welcome to the forum, Patrick.
If your budget can stand it, I would go for a newer mid sized combo kit.
Sydney, Australia
jw2170 is offline
post #7 of 16 (permalink) Old 10-07-2014, 06:54 AM
Bushwhacker's Avatar
First Name: David
Default Busted Craftsman Router
Thank you!
I once had, well, I still have it. A 1/4 inch Craftsman Router. I used it free hand and mounted under my table in its original mount. First I believe I broke the shaft lock so I had to vice grip the shaft to change a bit. Then while using it, the whole motor fell out under my table, just hanging there by one brush wire. sad. I rewired the other brush and put it all back together. The hand switch for off and on burned up, so I wired it "on". Had to just plug it in and off it went. I finally purchased a Ryobi table and router with a 1/2 1/4 drive. My wife will tell me about my old favorite tee shirts, it time to let it go.
When the enemy is in range, so are you.
Bushwhacker is offline
post #8 of 16 (permalink) Old 10-07-2014, 08:16 AM
BrianS's Avatar
First Name: Brian
Hi Patrick. Welcome to our little corner of the 'net.
As others have stated, it's time to replace it. New Craftsman routers can be had for around $120 or so, and there are packages available with both fixed and plunge base. The best of both worlds... fixed for the table, pop the motor out and put it in the plunge base for free hand work. Black Friday sales are coming too... even better deals.
Brian
(Origin uncertain)
BrianS is offline
post #9 of 16 (permalink) Old 10-07-2014, 08:20 AM
If the router was running fine before the brush went and a new brush is fairly cheap and you are capable of replacing it yourself then it is worth doing. If any of those conditions aren't met then it's time for a new one. There is some value to someone for the copper inside it if you go that way.
Welcome to the forum.
post #10 of 16 (permalink) Old 10-07-2014, 09:31 AM
I'm with the new router folks. Repair is what happens between short intervals of it working. Consider popping for a Triton TRA001 if you can manage it, next comes Bosch in my opinion.
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
