Edge guide retaining screw - Router Forums
post #1 of 7 (permalink) Old 10-10-2014, 12:37 PM Thread Starter
First Name: Lou
Default Edge guide retaining screw
Does anybody happen to know what thread size is used in the base of a Ryobi RE 180 PL
base that retains the bars for edge guide. The user manual does not even mention the threaded holes.
LouPen is offline
post #2 of 7 (permalink) Old 10-10-2014, 02:46 PM
Lou: I can't answer your question, but a few suggestions:
1) if you're reasonably close to a Ryobi distributor, stop in and and see if they have a parts catalogue.
2) drill the holes out and retap to a common thread size
3) gently try a 10-32 screw in the existing hole (maybe 1/4 - 20 as well, although they may be metric, in which case see #2...)
DaninVan is offline
post #3 of 7 (permalink) Old 10-10-2014, 02:57 PM
it will be metric...
take the guide w/ to the hardware store...
post #4 of 7 (permalink) Old 10-10-2014, 04:14 PM
First Name: Earl
Agreed, i'll place my bet on M5 or M6. (and i think Stick meant to take the base--where the threads are)
earl
greenacres2 is offline
post #5 of 7 (permalink) Old 10-10-2014, 04:49 PM
earl
correct...
post #6 of 7 (permalink) Old 10-10-2014, 09:41 PM
There are so many issues these days with whether a fastener is Imperial or metric that it really pays to have pitch gauges and learn to use them. I bought a combo set for about $5 that I keep in my tool box. Saves a lot of time by eliminating guesswork. The most common metric threads are .75, 1, 1.25, and 1.5 in the bolt sizes we most commonly deal with. Metric threads are measured in threads per millimetre whereas Imperial threads are measured in threads per inch.
post #7 of 7 (permalink) Old 10-13-2014, 05:43 AM Thread Starter
First Name: Lou
Thanks for all the suggestions, I guess I'll find a gave or bring to base to the hardware store for a match-up
LouPen is offline
DW 6913 edge guide oldrusty Portable Routing 11 12-05-2014 01:35 PM
Bosch Router Edge Guide 82995 Joel Eggerhardt Jigs and Fixtures 3 03-18-2014 12:45 PM
Edge guide and circle cutting rt_knir Portable Routing 3 04-30-2012 09:46 AM
Edge guide for my PC 890 paulcomi Portable Routing 30 03-11-2012 03:22 PM
Rockler Router Edge Guide reds_21 Jigs and Fixtures 1 02-06-2005 10:25 PM
