Mounting a Skil 1810 router :help: - Router Forums
post #1 of 6 (permalink) Old 10-13-2014, 07:10 PM Thread Starter
Knothead47's Avatar
Default Mounting a Skil 1810 router :help:
I bought a Skil 1810 a long time ago but only my son has used it so far. I went to the new Toolbox/Woodcraft store in Chattanooga and bought a Kreg benchtop router table. I got it together and am getting ready to install the router on the insert. I don't want to mess it up. Here goes: Do I mount the router on the insert without the black baseplate? Or do I mount the router on the baseplate and then mount the router directly to the insert? Here's the dilemma- one of the screws holding the baseplate on had the Phillips slots messed up and I had to take the three screws out and turn the baseplate to loosen it. It is an odd metric size. If I have to mount the baseplate on the router, I am up the creek as I am short one screw. I did find a place in California that stocks them- 4 cents per screw and six bucks for S&H.
Router folks, your advice is most welcome. Thanks in advance. Looking forward to making lots of noise, chips, and sawdust.
FWIW, the screw is metric- DIN 965 M4-10X4.8H!
John T.
Knothead47 is offline
post #2 of 6 (permalink) Old 10-13-2014, 07:18 PM
Here's the dilemma- If I have to mount the baseplate on the router, I am up the creek as I am short one screw. I did find a place in California that stocks them- 4 cents per screw and six bucks for S&H.
yes on without the base plate...
ace hardware or the the like for the screw....
very common screw and if the new screw protrudes through the router base by a fuzz there shouldn't be any issues...
take you router base w/ you...
all else fail, retap to SAE...
post #3 of 6 (permalink) Old 10-14-2014, 04:37 AM Thread Starter
Knothead47's Avatar
Thanks. I didn't find the screw online with Ace or anyone else locally. Will check with the Ace store as they have a lot of things the others don't have.
John T.
post #4 of 6 (permalink) Old 10-14-2014, 04:40 AM
you know you can use socket head screws...
post #5 of 6 (permalink) Old 10-14-2014, 05:00 AM
here you'll see that screw is common to Bosch...
Skil 1810 Parts List and Diagram - (2610915609) : eReplacementParts.com
post #6 of 6 (permalink) Old 10-14-2014, 05:52 AM Thread Starter
Knothead47's Avatar
Stick 486, didn't think of regular socket head screws as I won't need the countersink head for the insert. I should find something that would be the small thread and a length for the insert. Again, thanks!
A socket head screw with a flat washer should do the trick!
John T.
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
Bosch RA 1180 Router Table & Skil Router sjrhynard Starting Off 4 01-15-2010 05:10 PM
Table mounting questions for a Craftsman router. tdsapp Table-mounted Routing 25 12-17-2009 07:58 PM
