Clean starts and finishes? - Router Forums
post #1 of 8 (permalink) Old 10-15-2014, 12:17 AM Thread Starter
tak35bne's Avatar
First Name: Dave
Default Clean starts and finishes?
When using the Triton router with the supplied fence I get a little wonky on the start and on the exit of the material.....cuts like a 19mm wide x 9mm deep dado for t-track. What are the tricks to starting a clean cut and then exiting the material without a deviation.
Dave
tak35bne is offline
post #2 of 8 (permalink) Old 10-15-2014, 12:49 AM
Forum Moderator
Semipro's Avatar
First Name: John_*
Dave I believe you are taking to deep a bit, 1/8" per cut make 3 passes
Semipro is offline
post #3 of 8 (permalink) Old 10-15-2014, 05:36 AM
Bodger96's Avatar
First Name: Bob
Lighter passes would help. Control of the router with the work piece secured or control of the work piece with the router secured. Long fence and bigger sub base (Mine is rectangular approx. 11" x 9"). This arrangement has helped me ever since I was a beginner forty some years ago.
Regards Bob
Bodger96 is offline
post #4 of 8 (permalink) Old 10-15-2014, 07:24 AM
Adding a bit of scrap to the end of the peeve you're routing helps.
Fraise is offline
post #5 of 8 (permalink) Old 10-15-2014, 08:23 AM
MAFoElffen's Avatar
Plunge router or fixed base?
OP said he was doing a T-Track profile, so... If blind (fixed start and/or finshed, away from an edge), then I drill a hole with a forstner bit (just slight bigger than the diameter of the t-slot bit) at where the t-bolt will drop down into the profile. Start the slot with a straight bit or spiral bit, in steps, about 1/4" depth of cuts. Then the T-Slot bit.
MAFoElffen is offline
post #6 of 8 (permalink) Old 10-15-2014, 09:00 AM
First Name: Brad
And at the beginning. Especially if you can not get enough of the router plate on the work piece for a stable platform.
Also, always keep in mind which direction you are routing in. Sometimes the finish is the beginning, and vice versa.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #7 of 8 (permalink) Old 10-15-2014, 10:59 AM
Forum Moderator
MT Stringer's Avatar
Dave
Would something like this help? I use a flush trim bit and make several passes. You could also use a guide bushing.
A piece of scrap on either end would help prevent tearout.
Name:	2014-09-19 19.38.10.jpg
Name:	2014-09-19 19.13.27.jpg
Name:	2014-09-19 19.04.54.jpg
MT Stringer is offline
post #8 of 8 (permalink) Old 10-15-2014, 12:43 PM
RJM60's Avatar
First Name: Robert
Groove is for t-track, not t-slot, right?
Oversized base is another option.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
