5mm rebate - Router Forums
post #1 of 13 (permalink) Old 10-28-2014, 03:39 PM Thread Starter
First Name: Paul
Default 5mm rebate
Hi All, I am new to the forum and only a little experience of routing. I have an oval shaped piece of teak, 500mm by 200mm by 6mm thick. I want to rebate the edge 5mm wide by 3mm deep. Is there a special bit for the job and can it be done free hand.
rgds RPP
RigPigPaul is offline
post #2 of 13 (permalink) Old 10-28-2014, 03:50 PM
Semipro's Avatar
First Name: John_*
Hello Paul , glad you found us, it's great to have you as a member of the community, welcome to Router Forums.
Thank You John
Semipro is online now
post #3 of 13 (permalink) Old 10-28-2014, 04:00 PM
First Name: Darryl
Paul,
try using a rabbet bit. They are a straight bit with a bearing at the end of the arbour. The difference in size between the bearing and the bit is the depth of the rebate. Have a look at this website for ideas, and then see what you can find locally.
http://www.carbatec.com.au/835-rabbeting-bits_c17590
Darryl
Providing Web and IT services through my own business (Darbeth) by day, and by night , saving my customer's sanity.
Escaping to the workshop to create things out of slabs of wood by day or by night , to save my own sanity.
darsev is offline
post #4 of 13 (permalink) Old 10-28-2014, 06:27 PM
old55's Avatar
First Name: Ross
Welcome to the forum Paul.
Ross,
old55 is offline
post #5 of 13 (permalink) Old 10-28-2014, 06:40 PM
Welcome to the forum Paul. It's a simple job that can be done in minutes with the bit Darryl suggested and it can be used handheld or on a router table.
post #6 of 13 (permalink) Old 10-29-2014, 07:05 AM
can also use a edge guide clamped on with c clamps a simple
piecee of wood will work I use 1/2 "aluminum angle
cptjack is offline
post #7 of 13 (permalink) Old 10-29-2014, 07:58 AM
First Name: Darryl
Cptjack, if I understand what you are saying, that would work well for straight timber, but Paul has an oval shaped piece.
darsev is offline
post #8 of 13 (permalink) Old 10-29-2014, 01:05 PM
First Name: Andy
I see you're in the UK Paul. Bearing-guided bits for such small rebate sizes aren't too common. Especially to metric dimensions, even though we supposedly went metric in the 1960s.
I think Wealden Tool is your best bet. This looks like what you need:
Wealden Tool Company Limited Small Series
Personally I'd go for the T1705 down-shear version for the best surface finish. According to the list, that cutter with bearing TB450 will give you a 5mm rebate.
AndyL is offline
post #9 of 13 (permalink) Old 10-29-2014, 03:31 PM
Country: South Africa
First Name: Denis
Hi Paul - a bearing-guided rebate bit will do the trick as a number of posters have stated. You will battle to find a bearing/bit combination that will give a 5mm rebate. You will probably have to settle for a 1/4" rebate.
A note on terminology. Your original post used the term free-hand routing. You should have said hand-held routing (as opposed to table routing). Free-hand routing is hand-held routing where the user's eye/hand coordination determines the result. There is no other guidance mechanism. A rebate bit is bearing-guided.
Denis Lock ("Routing with Denis')
denisl is offline
post #10 of 13 (permalink) Old 10-29-2014, 05:29 PM
MT Stringer's Avatar
This is a set that I have.
Buy WoodRiver Rabbet Router Bit Set 1/2" SH at Woodcraft.com
Changing bearings changes the cutters width. You raise or lower the router to adjust the depth.
Maybe you can find something like this in metric.
As you can see I used mine in a router mounted under a table.
Hope this helps.
Name:	2014-10-10 14.27.52.jpg
MT Stringer is offline
Groove and Tennon Joint Construction neville9999 General Routing 3 11-19-2013 10:15 AM
Need to rout a rebate on a small frame - table or hand-held? cagenuts General Routing 5 02-08-2011 09:29 PM
Boring 5mm shelf pin holes stevesie Guide Bushings and Templates 17 03-08-2010 02:00 PM
Rebate cutting Snapper Table-mounted Routing 2 09-16-2008 10:20 AM
Dewalt 3 base router rebate herbfellows Lobby 2 02-15-2008 12:29 AM
