Multi Rabbeting kit - Router Forums
post #1 of 6 (permalink) Old 11-03-2014, 12:09 PM Thread Starter
Country: South Africa
First Name: Johann
Send a message via Skype™ to johannmendelsohn
Default Multi Rabbeting kit
I have bought a multi rabbeting kit. I need to cur 5/8 x 5/8" rabbets to the inside of a frame similar to a picture frame. The bit is about 11/16 high and 1 3/8" diameter. Can I use this free hand, bearing against the wood, or must it be used in a router table?
Thank you!
johannmendelsohn is offline
post #2 of 6 (permalink) Old 11-03-2014, 12:46 PM
Al B Thayer's Avatar
First Name: Al
It depends on a few things. How wide is the wood your cutting? Will you lay the wood flat or is it on an odd angle? Can you hog out most of it on the table saw? I would take at least 3 passes to get to the final cut.
For me without more info or a picture, I would make the cut on the router table.
Al
The best things in life, aren't things.
Al B Thayer is offline
post #3 of 6 (permalink) Old 11-03-2014, 08:14 PM
As Al suggested, it depends on if the frame is wide enough so that the router does not tip.
Other that that, I would say yes..
Does you bit have multiple bearings to set the width of cut?
835-001 / 501 / 502 Rabbeting Sets : CARBA-TEC
Sydney, Australia
jw2170 is offline
post #4 of 6 (permalink) Old 11-04-2014, 05:27 AM Thread Starter
First Name: Johann
Multiple bearings, yes. Multiple passes probably safest.
post #5 of 6 (permalink) Old 11-04-2014, 07:36 AM
First Name: Al
My understanding is the pieces are joined in a box? This can be done by hand but if at all posible do it on a table. The tip factor can be a project wrecker. If the surface the router rides on is wide you will be fine.
Posting pictures for these types of questions can really help.
Al
post #6 of 6 (permalink) Old 11-04-2014, 11:53 AM
I always prefer the table for such cuts. Very hard to keep the hand held router steady enough not to gouge here and there...at least it is for me.
For Sale: FS: Akeda DC16 dovetail jig + accessory kit chrisexv6 Woodworking Classifieds 4 01-12-2011 08:44 AM
another kit or a dedicated table router? rprice54 General Routing 11 08-06-2009 07:51 AM
