problem trimming formica - Router Forums
post #1 of 11 (permalink) Old 11-12-2014, 08:14 AM Thread Starter
Default problem trimming formica
I'm building some shelves and was using the bosch 1618evs mounted on my router table. I am laminating all of the legs which are 2" oak then cutting a 45 deg angle on all 4 sides. The problem is when I ran the piece (all edges counter clockwise), I'm getting some chipping on the edges of the formica. I have the speed cranked up to the max, 25k rpm. The 45 deg is a new Whiteside with a 1/2 shank.
On my test piece I started at about 4 then worked up to the max. The chipping decreased but I still didn't get a clean cut. Would anyone have any ideas on what's causing the chipping??
Ken
kln4 is offline
post #2 of 11 (permalink) Old 11-12-2014, 08:34 AM
Honored Member
First Name: pat
Hard to say, maybe crummy laminate. However, this cut, as light as it is, can be climbed.
The backwards feed may eliminate it.
Quillman is offline
post #3 of 11 (permalink) Old 11-12-2014, 08:43 AM
Nickp's Avatar
First Name: Nick
Is it possible you might be taking too much off at one time...? Or maybe feeding too fast...? Or both...? Is the Formica on the leading or trailing edge of the cut...?
Welcome to the forum, Ken...
Nick
Nickp is offline
post #4 of 11 (permalink) Old 11-12-2014, 10:46 AM
Welcome to the forum Ken. I've usually only had problems when the laminate isn't securely glued to the substrate.
post #5 of 11 (permalink) Old 11-12-2014, 11:22 AM
Semipro's Avatar
First Name: John_*
Hello and Welcome to the forum Ken.
Thank You John
Semipro is online now
post #6 of 11 (permalink) Old 11-12-2014, 08:18 PM
First Name: Brad
Not my first choice in a router bit to trim formica\melamine. I would use a down cut spiral bit to trim the laminate.
You may have to make a jig to orient the leg at a 45 degree to accomplish the cuts you need.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #7 of 11 (permalink) Old 11-13-2014, 11:21 AM
Hi Ken ,welcome,
I don't understand, are you taking a 2"X2" leg, laminating all 4 sides with p-lam and then chamfering the corners with a 45 degree chamfer bit? If that is the case you will be cutting both the upper and lower P-lam at the same time. Are you getting chipping on both the top and bottom? if this is the case I think you are using the wrong bit. You might try making a jig to lay the leg at 45 degrees to a straight bit on a router table. A solid carbide bit might work best.
Herb Stoops is online now
post #8 of 11 (permalink) Old 11-13-2014, 04:14 PM
Ken
wrong bit...
you need one designed/engineered for laminate...
post #9 of 11 (permalink) Old 11-17-2014, 04:29 AM Thread Starter
Thanks for all replies.
I figured out the problem
1. I forgot to set the bosch to max speed. Once I set it to 6 the chip problem went away.
2. I forgot to roll my edges before cutting the 45, so every time I ran the piece it I got some minor chipping at the top and bottom of my test pieces.
I am using formica brand, and the "odorless" glue. After I roll it still need to set for about half an hour then I run the piece with the edge cutter first. I put in 45 cutter then run the pieces, no more chipping.
PS: It took me awhile to figure out how to get on the board. When I first registered I cleared my history, all of it, to get rid of tracking cookies. I blew away everything.
kln4 is offline
post #10 of 11 (permalink) Old 11-17-2014, 11:00 AM
It has has to be stuck down good and tight or I think it starts to vibrate ansd it can chip when it does that. You also want to make sure that the overhang on the lam is less than half the diameter of the bit or it can shatter chunks off from that too. I've done quite a few bevels on counter tops to expose a hardwood edge and had no problems if I followed those rules.
Introduction of myself and my problem. samfromhernando New Member Introductions 26 10-06-2014 10:08 PM
Problem With PC 4212 Jig dppatt Jigs and Fixtures 4 05-27-2013 01:44 PM
unique problem flush trimming jwoody New Member Introductions 3 01-01-2013 05:16 PM
Question about laminating MDF ? formica , hardboard tryingtokeepmyfingers Table-mounted Routing 19 04-06-2011 09:09 PM
Trimming mitered hardwood edging Drew Eckhardt General Routing 5 10-11-2008 07:59 PM
