Need collet nut for Bosch POF 500 - Router Forums
post #1 of 11 (permalink) Old 11-13-2014, 05:30 PM Thread Starter
Dimitri M's Avatar
Country: Greece
First Name: Dimitri
Default Need collet nut for Bosch POF 500
Greetings;
my old Bosch POF 500 (purchased in 1987!) still works well, as it is suitable for small jobs only, but recently the collet nut broke (metal fatigue fracture).
Does anyone know if and where I can find a replacement nut? Or what nut could be used alternatively?
With thanks
Dimitri M
"if you think it is important, you will find a way;
if you think it is not important, you will find an excuse"
Dimitri M is offline
post #2 of 11 (permalink) Old 11-13-2014, 06:25 PM
old55's Avatar
First Name: Ross
Dimitri I'm sure someone will be able to help you with you inquiry.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #3 of 11 (permalink) Old 11-13-2014, 09:06 PM
Welcome back good doctor. I haven't seen you post in while and was thinking about you the other day and here you are. I hope you've been well.
I did a quick search Dimitri and found something that may be promising. Buy Spare Parts for Bosch Router POF 500 A - 0 603 261 842 - Powertool Spares
post #4 of 11 (permalink) Old 11-14-2014, 06:23 AM
Bushwhacker's Avatar
First Name: David
Default Bosch collet nut
Originally Posted by Dimitri M View Post
Greetings;
With thanks
I found " Bosch Laser & Level Parts/ Parts Tree.com"
When the enemy is in range, so are you.
Bushwhacker is offline
post #5 of 11 (permalink) Old 11-14-2014, 03:48 PM
First Name: Not wanted here so I left
Good timing. I just bought a Bosch Colt router and the damn collet broke the first time I swapped bits out.
Have an Ordinary Day...
Kurtis ~|:-)
KomputerMan is offline
post #6 of 11 (permalink) Old 11-14-2014, 08:19 PM
Small Wood's Avatar
First Name: Cathy
Default replacement parts for Bosch pof 500
I would try here, I get all my replacement parts from ereplacement or partstree.com
Small Wood is offline
post #7 of 11 (permalink) Old 11-16-2014, 11:35 AM
Phil P's Avatar
First Name: Phil
Hi Dimitri
I've had a scout around for you through our suppliers in the UK. If yours is the older type collet where the nut uses a 14mm wrench and the top end of the collet is 8mm diameter then I'm afraid that Bosch have discontinued the nut (although not the collets). If yours is the newer one with the 10mm collet and where the nut is 17mm AF then you are probably in luck. Take a look at the small inset drawing here to see what I mean.
Regards
Phil
Phil P is offline
post #8 of 11 (permalink) Old 11-16-2014, 12:36 PM
First Dimitri shows up and now you Phil. I hope you are back to join in the discussions. We've missed your sage advice.
post #9 of 11 (permalink) Old 11-16-2014, 02:55 PM
Phil P's Avatar
First Name: Phil
Hi Chuck
Yep. It's like the ghosts of Christmas past
Regards
Phil
Phil P is offline
post #10 of 11 (permalink) Old 11-17-2014, 07:24 AM Thread Starter
Dimitri M's Avatar
Country: Greece
First Name: Dimitri
Number one, I am overwhelmed by the number of friends who greeted me back. I owe each and everyone of you a personal reply, but I am at work now, so talk back later.
Number two, I had a brief look at the various sources. Even if I find the bit, it will be more than 20US$ or equivalent. On the other hand, a heavily used such router comes up in e-Bay now and then, for a fiver - what do you think, friends?
With thanks
Dimitri M
Bosch POF 40a nut and collet Pugdud General Routing 8 11-14-2013 03:32 AM
bosch 1200 pof ae collet problem claytonjohnroby General Routing 6 08-23-2012 10:37 AM
Wanted: Skil 1825 router collet nut gertmcfly Woodworking Classifieds 0 12-14-2011 06:44 PM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
Elu MOF31 nut and collet daki222000 Portable Routing 6 10-20-2008 01:18 PM
