Designing a Santa Hat Inlay Kit - Router Forums
post #1 of 6 (permalink) Old 11-14-2014, 03:58 PM Thread Starter
First Name: Not wanted here so I left
Default Designing a Santa Hat Inlay Kit
This is a picture of the wreath I built last year for the Boise Festival of Trees. Not bad for a first attempt at building a wreath, or in other words I thought it turned out pretty cool... Yeah... that's my Daughter, she turned out pretty cool too!!!
For the wreath being built this year I'm using AmbersBear as the main focal point of the wreath hanger. Because it's Christmas I decided to put a Santa Hat on the inlay too. I found this AWESOME piece of burled hard maple that should make a pretty cool hanger.
I needed to design a Santa Hat that will fit on the Bear and look good too! I've been wanting to add accessories to AmbersBear for awhile so I thought why not now?
The only way to see if you like a design is to build a prototype. I built this AmbersBear a year or so ago and just had it hanging around so it became my Rev 1 prototype!
Using the alignment transparency I positioned Santa Hat inlay on the head of the Bear. Then I marked the edges of the transparency so I could align the template on the base material. Once I placed the Layer 1 template on the base material I traced the circular alignment marks, from the template, onto the base material. I use the circles inside the template for alignment because sometimes during the manufacturing process the edges of the template get a little wonky.
Using double side tape I affixed the template to the base material and routed out the Layer 1 void. This where the red part of the Santa Hat is going to be placed.
Using the same Layer 1 template I cut the inlay from a piece of Red Heart I had laying around and then glued it into the void.
After letting the glue cure for a few minutes, I affixed the Layer 2 template to the base material using the circular alignment marks as my guide. Then I routed out the the Layer 2 void.
I decided to use an epoxy with glitter to fill the Layer 2 voids. As soon as the resign dries I'll sand it down and finish the prototype. I don't really like my first attempt at building a Santa Hat so there will be a Rev 2. But isn't that the way it goes with woodworking? Try something if you like it replicate it, if not improve it!
I'm thinking I need to make the brim of the hat a little more curved and a little wider. What do you think? What would you do to make the Santa Hat fit AmberBear's head? Thanks in advance for the help!!!
Have an Ordinary Day...
Kurtis ~|:-)
KomputerMan is offline
post #2 of 6 (permalink) Old 11-14-2014, 04:25 PM
old55's Avatar
First Name: Ross
Nice.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #3 of 6 (permalink) Old 11-14-2014, 05:05 PM
Great job, Kurtis.
Sydney, Australia
jw2170 is offline
post #4 of 6 (permalink) Old 11-15-2014, 09:02 AM
MEBCWD's Avatar
Kurtis,
I agree with you that the brim of the hat needs to be a little more curved and a little wider. Good start though!
MEBCWD is online now
post #5 of 6 (permalink) Old 11-15-2014, 11:06 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Kurtis,
Those are nice Christmas decorations you have there! Having three (now grown) daughters and 13- grandchildren, I would also like to say that your daughter is a real cutie!
OPG3
Tweak everything!
OPG3 is offline
post #6 of 6 (permalink) Old 11-17-2014, 02:18 PM Thread Starter
Sorry about the pictures being removed by the site admin guys. My intent was to show the process I used while building the prototype and the pictures I had embedded in there were being used for that purpose.
Shame too because the Rev 2 prototype is looking pretty good... IMHO of course!
Thanks Otis... I think she is too... but I am biased!
Kurtis ~|:-)
Question About Whiteside Inlay Kit Jerry Bowen Tools and Woodworking 6 06-15-2014 08:27 AM
Inlay bushing kit questions Jray Guide Bushings and Templates 6 05-17-2009 03:11 PM
Bushing set vs. inlay kit ? mharwell01 Guide Bushings and Templates 7 02-02-2008 04:44 AM
