Metal Laminate - Router Forums
post #1 of 8 (permalink) Old 11-21-2014, 09:00 AM Thread Starter
Default Metal Laminate
Hello,
Working on a display cabinet for a customer who wants to add some inset metal laminate (brushed brass- satin chrome finish) into the drawers and doors. New to the metal laminate I was looking for some advise on routering this material. The metal laminate has the typical phenolic backing just like plastic. I am planning to first adhere the laminate to a substrate material, probably 1/4" Baltic birch. Rough cut my pieces then pattern trim them to finished size....so,
1. What type of router bit?
2. What speed for the router?
3 What feed rate is recommended?
Any other suggestions would also be appreciated (I.e. Adhesive type, finishing the edges, etc.)
In advance of all courtesies extended, THANK YOU!!!!!
John
JPF WOODWORKING is offline
post #2 of 8 (permalink) Old 11-21-2014, 09:03 AM
First Name: Brad
I thing a carbide down cut spiral bit would be best to reduce tear out and any tendency for "wrinkling" along its cut edge. A high speed should provide a clean cut unless specified otherwise by the mfg. Feed rate should not be too critical, as long as you provide smooth, even strokes along the edge.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #3 of 8 (permalink) Old 11-21-2014, 09:56 AM
Onsrud has a bit that is specially for that that looks more like a rasp. They've been advertising it on eBay under their user/Co. name Onsrudcutter2010. It was cheap and free shipping so I would suggest you have a look for them and see if they are still listing that one.
post #4 of 8 (permalink) Old 11-21-2014, 12:08 PM
This looks interesting...
InVectra Metal Laminate Trim Bits
DaninVan is offline
post #5 of 8 (permalink) Old 11-21-2014, 10:10 PM
First Name: Brad
$57 to $160 for a carbide spiral bit with a gussied up name.
Save your money and but a 1/4" one for $13. $30 with a roller bearing from Whiteside.
post #6 of 8 (permalink) Old 11-22-2014, 07:37 AM
Phil P's Avatar
First Name: Phil
Hi John
I've done my fair share of retail cabinets/counters with this stuff in the past. I'd suggest that you stick with a brazed carbide router bit or possibly a replaceable tip carbide bit - this is because the stuff is extremely aggressive and tends to burn grooves in your cutters fairly easily. In turn that means that you'll need to move the cutter up or down a bit from time to time to even out cutter wear
Router speed is same as normal for laminate and feed rate same as you'd normally use
A couple of other points worth noting; this stuff can take on a heck of a curl, especially if it has been stored badly (even if only tightly rolled for a day or two in transit). It may be necessary to unroll it and flatten it out between two sheets of plywood and some weights in really bad cases. Also when you spread the adhesive on it make sure that you put enough adhesive on - don't be stingy! I've found with some aminates it may be necessary to lay down a thin skin of contact adhesive, let that dry then put on a second coat to prevent it curling up off the carcassing - you don't know whether this is needed until you start laying down the laminate, I'm afraid. I'm not keen on using water-based adhesives with it because I don't think they have the holding power of solvent-based contact adhesives (saying that it may be all you can get). The other point is about marring. I've found metal laminates to be a lot worse than even high gloss solid colours for this, so protect your surfaces with a layer of 2in or 3in masking tape when trimming it and finish with a fine-cut hand file. Leave the protective plastic on until the very last minute and vacuum off dust frequently - even the dust produced by trimming it can scratch unprotected surfaces because it contains sharp metal strands and metal dust particles
Regards
Phil
Phil P is offline
post #7 of 8 (permalink) Old 11-22-2014, 07:49 AM
First Name: Al
I just laminated my table saw extension table with a brushed aluminum (see above thread).Found it cut wee with a standard carbide flush trimmer,but in a couple places when trimming the top,the sides were scuffed some what,so as Phil said,tape would be a good idea.One other problem I had,not a biggie for my purpose but would really annoy me in a kitchen etc is I some how ended up with one very small dent,not sure how that happened.
Btw,only used this because it was a cheap kijiji(like craigslist) find
al m is offline
post #8 of 8 (permalink) Old 11-23-2014, 12:21 PM Thread Starter
Thanks everyone, really appreciate the advice! JPF
logic trace program for metal objects woodman12 CNC Routing 0 03-19-2014 07:02 PM
safe to assume laminate table top has no embedded metal? mrblint Project Plans and How To 13 02-21-2014 07:21 PM
Routing laminate?? Bshmstr General Routing 8 04-01-2013 12:33 PM
Laminate counter with oak edge kefjens General Routing 13 03-27-2009 04:37 PM
