router table top - Router Forums
post #1 of 4 (permalink) Old 11-21-2014, 10:23 AM Thread Starter
Default router table top
I recently acquired two pieces of 3/4" phenolic 30"x 40". I want to make
a top for a router table which i made. My problem being i have never routed
any plastic or phenolic, lots of wood, but no phenolic. I want to route out
the center to accept a router plate and i'm thinking this will have to be exact,
right on, as in almost perfect. Any suggestions or ideas on how to go about
this ? Thanks in advance, Logan
backhoe04 is offline
post #2 of 4 (permalink) Old 11-21-2014, 11:00 AM
PhilBa's Avatar
First Name: phil
I've done thin stuff no problem. Though, I have heard that it dulls cutters pretty fast. The dust is nasty, have good collection and use a respirator.
I would first cut the opening with a jig saw and try to leave no more than 1/4" to the router. I assume you will be using a template.
PhilBa is offline
post #3 of 4 (permalink) Old 11-21-2014, 06:04 PM
First Name: Al
Phenolic routers very well but as stated above is hard on the cutter.
Phil is correct , remove excess material first if you can
al m is offline
post #4 of 4 (permalink) Old 11-21-2014, 10:07 PM
First Name: Brad
`1
Once you have decided on a router and lift\plate that supports it, I would use the recommended template and router bit by that lift\plate supplier.
Cutting out the excess with a jig saw is a good plan too, as others have suggested.
Good luck and keep us posted on your progress.
Not even gonna ask who you had to kill for those two large sheets of phenolic!!!!
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
Positioning Router in Table Top Teddytim1 Table-mounted Routing 12 01-13-2014 07:05 AM
Bench Dog BenchTop vs. The Super Bench, Bench Top Router Table emergencyshutdown Table-mounted Routing 8 11-14-2011 01:58 AM
Took the new router table top for a spin. 30coupe Table-mounted Routing 7 01-26-2011 12:26 PM
How to best attach router table top to cabinet? xvimbi Table-mounted Routing 3 05-28-2010 07:30 AM
Grumble - How to remove snapped screw from router table top? xvimbi Table-mounted Routing 14 02-21-2010 05:04 PM
