repairs!??! - Router Forums
post #1 of 10 (permalink) Old 11-24-2014, 08:54 AM Thread Starter
shuja.shaher's Avatar
Country: India
First Name: Shuja
Default repairs!??!
Hi everybody
You know I am new. not having control on the router not setting the depth. I ended up with this. How do I repair. I dont want to paint it. I want to either wax it or varnish.
thanks.
shuja.shaher is offline
post #2 of 10 (permalink) Old 11-24-2014, 09:40 AM
Originally Posted by shuja.shaher View Post
Hi everybody
You know I am new. not having control on the router not setting the depth. I ended up with this. How do I repair. I don't want to paint it. I want to either wax it or varnish.
thanks.
edge guide and rout the two edges clean...
square shoulder dado the cut and fill it w/ a contrasting wood...
reroute your your grove as you originally intended....
leave the contrasting wood as an accent....
post #3 of 10 (permalink) Old 11-24-2014, 05:03 PM
Hi Shuja, it almost looks like you were routing freehand.
I endorse Stick's method, using an edge guide..
PS..what router are you using, so that we may be able to help with the depth setting.
Sydney, Australia
jw2170 is offline
post #4 of 10 (permalink) Old 11-25-2014, 06:14 AM Thread Starter
Country: India
First Name: Shuja
James, I did have the edge guide, but I under estimated the power of the router. It became free hand.
Stick, contrasting wood is a good idea. But willit hold? How deep / wide should I go to fill it?
post #5 of 10 (permalink) Old 11-25-2014, 07:33 AM
cut a filler and lay it in place...
it's a matter of aesthetics...
yes it will hold...
you need to decide if the banding comes out wide or thin...
there is nothing to stop you from practicing on scrap to get a feel for depth and widths..
post #6 of 10 (permalink) Old 11-25-2014, 08:47 AM Thread Starter
Country: India
First Name: Shuja
Thank you Stick. I get the point.
post #7 of 10 (permalink) Old 11-25-2014, 05:52 PM
Exclamation
Hi Shuja, if you were using an edge guide, I would check your feed direction.
If you go anti clockwise, the router will hold tight against the side. If you go clockwise, the router will push the edge guide away from the timber.
Just my tip...
PS I like that idea for a contrasting wood inlay.
Sydney, Australia
jw2170 is offline
post #8 of 10 (permalink) Old 11-26-2014, 03:46 AM Thread Starter
Country: India
First Name: Shuja
Thank you James. Yes sir, I was actually going anticlockwise. But as I said it just went awry.
post #9 of 10 (permalink) Old 11-26-2014, 03:40 PM
MT Stringer's Avatar
It looks like you were going in the wrong direction.
See my edited pic of your board. Sorry, I can't draw a straight line.
Is this the direction your router traveled as you made the cuts?
Y'all correct me if I am wrong.
Edit: I found some reading material.
http://www.highlandwoodworking.com/routersgoleft.aspx
MT Stringer is offline
post #10 of 10 (permalink) Old 11-27-2014, 07:04 AM Thread Starter
Country: India
First Name: Shuja
Mike, I actually started at the top right corner and went left i.e., against the arrow you have shown. The bottom groove was made from the other corner to the top right corner again opposite to your arrow. I connected the two grove together with the shorter line afterwards. As I said, I simply could not control the router at the particular moment. Once I started after the initial hiccup, things went well. I connected the two longer grooves with shorter groove without any guide. By then I could get the feel of the machine.
Thank you for the reading material.
Wood strip canoe repairs bobbotron Starting Off 21 08-02-2012 01:02 AM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
circular saw repairs -- help! allthunbs Tools and Woodworking 25 05-30-2011 02:38 PM
House repairs xplorx4 Show N' Tell 46 06-17-2009 01:16 AM
