Plunge base for Marvel 40 trim router - Router Forums
post #1 of 9 (permalink) Old 11-26-2014, 03:58 PM Thread Starter
Default Plunge base for Marvel 40 trim router
A while back I purchased an MLCS Marvel 40 trim router. I was disappointed to find that the plunge base that came with it was junk. I'd like to replace it with a plunge base for the Bosch palm router or Makita RT0700 but I'm worried they may not fit. The body diameter of the Marvel 40 is 2 5/8 inches. Has anyone fitted an alternate plunge base to the Marvel 40 or can anyone recommend a plunge base with a 2 5/8 inch opening?
johnskudlarek is offline
post #2 of 9 (permalink) Old 11-26-2014, 04:45 PM
old55's Avatar
First Name: Ross
Welcome back to the forum John. I'm sure some of the members will be able to give advice that may help.
Ross,
old55 is offline
post #3 of 9 (permalink) Old 11-27-2014, 11:17 AM
Welcome back,John, Hmmmmm I have never heard of any swapping router bases,that will be interesting might run into problems with height adjustment. I will measure all my bases and see if any fit that diam.
Herb Stoops is offline
post #4 of 9 (permalink) Old 11-27-2014, 11:23 AM
even if the dia is the same what about the key slots???
Stick486 is offline
post #5 of 9 (permalink) Old 11-27-2014, 01:24 PM Thread Starter
Stick.....key slots won't be a problem......no key on the Marvel 40.
post #6 of 9 (permalink) Old 11-27-2014, 01:43 PM
body studs???
take the motor to a big box and see if it an router bases there...
look to the Colt combo while you are there...
impressive piece of equipment..
Stick486 is offline
post #7 of 9 (permalink) Old 11-27-2014, 02:59 PM Thread Starter
Stick....I may have to resort to that. I was hoping some of the members might measure their bases and help me narrow the possibilities.
post #8 of 9 (permalink) Old 11-27-2014, 04:09 PM
Guest
First Name: Regis
John,
That entire router and especially the plunge mechanism is, indeed, junk and not only that, I had to spend $28 to return it. Good luck with your search for an alternate plunge base but I'd eat the return cost and send it back.
Regis
48394 is offline
post #9 of 9 (permalink) Old 11-27-2014, 04:12 PM
Originally Posted by Reg66 View Post
John,
Regis
and get the Colt...
Stick486 is offline
Plunge Router base for Table? JudgeMike Table-mounted Routing 7 05-19-2013 11:53 PM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
