Raised Panel Bit HELP! - Router Forums
post #1 of 16 (permalink) Old 12-04-2014, 01:03 PM Thread Starter
First Name: Scott
Default Raised Panel Bit HELP!
I had a 2hp craftsman router that I used to make 4 doors out of hard maple. The bit i used was a Yomico from ebay(cheapest i could find). I burnt out the speed controller on it in the process. I had the speed turned all the way dow but the router was vibrating a bit when running. I was using a horizontal cutter. I have a 3.25 HP router now. I'm wondering if I should buy a vertical bit or use the horizontal bit for cutting the panel profile. I'm scared of ruining my new 3.25hp Hitachi router...
What do you all use for cutting panel profiles? I like the idea of the horizontal bit with the back cutter...
ssevey17 is offline
post #2 of 16 (permalink) Old 12-04-2014, 01:14 PM
Gene Howe's Avatar
First Name: Gene
The first thing I would do is get a better bit. My experience with yonico bits leaves me a good deal less than impressed.
I use a CMT bit with a back cutter and set the speed at approximately 12000 RPM.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 16 (permalink) Old 12-04-2014, 01:27 PM
First Name: Duane
If you were cutting hard maple in 1 pass, could give less the stellar results. I'd cut it in 2, maybe 3 passes.
I also agree with Gene. Raised panel is not a good application for "cheapest I could find".
CMT, Freud, Whiteside, Sommerfeld, Just to name a few. I have also had pretty good use from Grizzly, MLCS, Woodline, etc.
Does the Yonico vibrate running free? If so, I would attempt to use it at all. Otherwise it may be ok with lighter passes.
Oh, and I am assuming your running this in a table? If not, QUIT, and buy or build yourself a router table.
Dmeadows is offline
post #4 of 16 (permalink) Old 12-04-2014, 01:49 PM
Originally Posted by ssevey17 View Post
I had a 2hp craftsman router that I used to make 4 doors out of hard maple. The bit i used was a Yomico from ebay(cheapest i could find). I burnt out the speed controller on it in the process. I had the speed turned all the way down but the router was vibrating a bit when running. I was using a horizontal cutter. I have a 3.25 HP router now. I'm wondering if I should buy a vertical bit or use the horizontal bit for cutting the panel profile. I'm scared of ruining my new 3.25hp Hitachi router...
that speaks volumes right there...
out of hard maple.
suspect router bearing failure...
failing bearings/brushes cause speed fluctuations that run rough shod over speed controls...
a bit out of balance...
too big of bites....
buy quality this time...
I like my Freuds...
CMT and Whiteside is good stuff too...
practice....
you won't ruin your new router...
but park that Yomico...
Horizontal or Vertical router tables...
Horizontal or Vertical shapers...
Bosch 1617 or 1619EVS routers....
what ever is the most appropriate tool for the mission...
Freud Quadra cut...
premium stuff...
post #5 of 16 (permalink) Old 12-04-2014, 02:29 PM Thread Starter
First Name: Scott
I took the cut in two passes. I'm definitely going to throw away my cutter bit. I wanted to buy a cheap but for my first go around to make sure I enjoyed building cabinets... And yes I build a nice router cabinet and was doing it on there.
But if I turn the speed all the way down and take 2-3 passes, it wont hurt my new router with the horizontal bit?
ssevey17 is offline
post #6 of 16 (permalink) Old 12-04-2014, 03:51 PM
First Name: Darryl
Scott,
More speed = less power. Less speed = more power. The less you cut in a pass the less load is put on the tool. So in general, slowing it down and cutting less means more power on a machine that has less load.
Darryl
Providing Web and IT services through my own business (Darbeth) by day, and by night , saving my customer's sanity.
Escaping to the workshop to create things out of slabs of wood by day or by night , to save my own sanity.
darsev is offline
post #7 of 16 (permalink) Old 12-04-2014, 05:38 PM
what's the diameter of the bit???
post #8 of 16 (permalink) Old 12-04-2014, 06:08 PM Thread Starter
First Name: Scott
The bit is 3" in diameter. Typically, how much do you take off in one pass? 3/8"? 1/2"?
ssevey17 is offline
post #9 of 16 (permalink) Old 12-04-2014, 06:32 PM
you free hand routing???
what's the total thickness of material you are removing???
post #10 of 16 (permalink) Old 12-04-2014, 07:02 PM
MT Stringer's Avatar
I used the Freud Quadra cut raised panel cutter. They come in several profiles. The Bosch 1617 handled it nicely. I also ran it at the slowest speed. I made three passes. there's always time to do it right.
Lots of good info in this thread. I was in the same situation as you, so I asked...
http://www.routerforums.com/table-mo...l-doors-2.html
MT Stringer is offline
How to use vertic raised panel router bit Dpaul Router Bits - Types and Usage 12 05-31-2014 03:49 AM
Raised Panel Wainscoting mprice Router Bits - Types and Usage 4 12-17-2012 07:20 AM
Raised Panel Backcutter with Rail & Stile Router Bit gbello Router Bits - Types and Usage 9 02-21-2010 01:29 AM
Raised panel bit TF-Kevin Router Bits - Types and Usage 1 07-14-2009 03:06 AM
raised panel router bits Dave2 Starting Off 7 03-30-2007 10:13 AM
