Need source for Bosch 1617 plunge sub base - Router Forums
post #1 of 19 (permalink) Old 12-09-2014, 09:37 PM Thread Starter
First Name: Jeff
Default Need source for Bosch 1617 plunge sub base
Looking for a new plunge sub base for my 1617. Apparently the material these are made from is very brittle in the cold winter temps we're having as my shop is not heated. This material reminds me of the bakelite they used for pick guards on old fender guitars. Had a little hang up sliding my router along a jig I use to radius stock and the sub base cracked and is now in two pieces. I can not find the sub base on ebay or google. Tried several Bosch sites as well. I find others but not the one I need. Any help would be greatly appciated. Thank you
Jeff
J Lacey is offline
post #2 of 19 (permalink) Old 12-09-2014, 09:40 PM
Jeff
call Bosch CS...
post #3 of 19 (permalink) Old 12-09-2014, 10:20 PM
MT Stringer's Avatar
bosch 1617 plunge base | eBay
MT Stringer is offline
post #4 of 19 (permalink) Old 12-10-2014, 12:05 AM
boogalee's Avatar
First Name: Al
part number for sub base is 2610997099
Al B
boogalee is offline
post #5 of 19 (permalink) Old 12-10-2014, 12:20 AM
Contributor of the Month
PhilBa's Avatar
First Name: phil
It shouldn't be very hard to make one. I'd use 1/4" lexan and then it wouldn't break again.
PhilBa is offline
post #6 of 19 (permalink) Old 12-10-2014, 12:46 AM
Making a new one sounds like a great suggestion, but what Stick said; it just shouldn't have broken. They're phenolic aren't they?
Like Phil points out, Acrylic or Poly-carbonate are probably better choices re the temperature(?)...
A GUIDE TO POLYCARBONATE IN GENERAL - PTS LLC
https://www.boschtoolsservice.com/Ho...ookieSupport=1
DaninVan is offline
post #7 of 19 (permalink) Old 12-10-2014, 06:31 AM Thread Starter
First Name: Jeff
Thanks for the replies. Finally located one on replacementparts.com $15 plus shipping.
May eventually make one but wanted to go ahead and get mine back together asap. The ebay link takes me to all the listed plunge bases but no sub bases on there that I can find. Thanks again, always good to come here for advise
Jeff
J Lacey is offline
post #8 of 19 (permalink) Old 12-10-2014, 09:04 AM
Honored Member
First Name: pat
Made for your plunger and the 1160/1 castings.
Quillman is offline
post #9 of 19 (permalink) Old 12-10-2014, 10:26 AM
PhilBa's Avatar
First Name: phil
Too bad it's acrylic. Polycarbonate/Lexan would be longer lasting. Though, to be fair, acrylic is probably a big step up from what ever the original base was made of.
PhilBa is offline
post #10 of 19 (permalink) Old 12-10-2014, 10:29 AM
You are right-on Quillman.
I have had Pat Warner sub bases for years and they are Top Quality.
Herb Stoops is online now
plunge or fixed base bellaw Table-mounted Routing 16 01-08-2014 04:49 AM
Plunge vs Fixed Base kstern New Member Introductions 20 03-02-2013 07:21 PM
Latest PC #890 plunge base. Birch General Routing 11 03-04-2009 01:15 PM
Converting fixed base to plunge base. -Sam- Portable Routing 4 09-30-2004 03:53 PM
PC 690 Plunge Base problem. NewMontanaWorkshop General Routing 11 09-27-2004 12:01 PM
