PC 7518 lock screw mod - Router Forums
post #1 of 11 (permalink) Old 12-10-2014, 12:05 AM Thread Starter
PhilBa's Avatar
First Name: phil
Default PC 7518 lock screw mod
I got a Porter Cable 7518 router to mount in a router table but have lately been using it for hand held routing. I actually like the weight of it and don't mind muscling it around.
But the base locking mechanism is pretty bad. I would wind up using pliers to tighten/untighten it. The bolt would spin around each time. I felt like I was going to break it every time. This got old fast.
So, I took a Rockler 1/4"-20 cam clamp and used it to replace the locking mechanism. What a difference it makes. Adjustments are super fast and the cam makes for a very solid lock. The lever sticks out a bit far when latched. I'd prefer a lever that curved around closer to the base when locked but I can live with this as it is.
Name:	pc 7518 20141209_155843.jpg
Name:	pc 7518 20141209_155823.jpg
PhilBa is online now
post #2 of 11 (permalink) Old 12-10-2014, 02:56 AM
Rogerdodge's Avatar
First Name: Roger
Great idea Phil , maybe something like this would help ?
Rog
Name:	Cam Clamp.png
Been at sea most of my life and still all at sea now.
Sometimes I sits and thinks and sometimes I just sits .
(M Twain)
Rogerdodge is offline
post #3 of 11 (permalink) Old 12-10-2014, 05:00 AM
First Name: Gary
Looks like a good solution. I have my 7518 in a table. I have been using a 6" adjustable to carefully tighten and loosen the bolt. Arthritis has robbed me of some strenght.
Gary Gill is offline
post #4 of 11 (permalink) Old 12-10-2014, 07:56 AM
I have used the cam lock from a bicycle seat post for many years on my PC690. It has the right curvature and is available for less than $5 at most bike stores. The bolt is small enough to just slide through the threads on the base and the adjuster nut that came with seat post lock works great.
senebraskaee is offline
post #5 of 11 (permalink) Old 12-10-2014, 08:37 AM
kp91's Avatar
First Name: Doug
Fantastic ideas guys! thanks for sharing
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #6 of 11 (permalink) Old 12-10-2014, 09:04 AM Thread Starter
PhilBa's Avatar
First Name: phil
Good idea - I'll have to check it out. The rockler cam clamps are cheap too - 10 for a pair.
post #7 of 11 (permalink) Old 12-10-2014, 09:06 AM Thread Starter
PhilBa's Avatar
First Name: phil
Rog
Where did you get it?
post #8 of 11 (permalink) Old 12-10-2014, 12:06 PM
Default Clamp to fit.
You could get a small block of aluminum and on your scroll cut the clamp to the shape needed.
oldtennisdude5 is offline
post #9 of 11 (permalink) Old 12-10-2014, 05:09 PM
First Name: David
I did the exact same thing to my router located under my saw table extension arm. It made it so easy to clamp the router tight in just one sweep of my arm. Guess great minds think alike.
ghosttracker is offline
post #10 of 11 (permalink) Old 12-10-2014, 05:20 PM
Rogerdodge's Avatar
First Name: Roger
They have them here Cam Lever (Cam Clamp) Plastic Handle - Steel Washer (WDS 367), Cam Levers & Clamps | WDS
An image search "Cam Clamp" should find some available in the States.
Rog
(M Twain)
Got a screw loose! idarwin Table-mounted Routing 4 09-07-2014 07:36 PM
Repairing Older Craftsman Shaft Locks MEBCWD Woodworking Articles 0 03-08-2012 07:55 PM
A simple fix for the screw gone too deep xplorx4 Show N' Tell 2 03-05-2010 12:48 PM
How To Destroy Screw Heads cabinetman Lobby 4 06-09-2007 06:03 AM
