Ryobi router troubleshooting, has it bitten the dust? - Router Forums
post #1 of 15 (permalink) Old 12-10-2014, 01:23 PM Thread Starter
First Name: sam
Default Ryobi router troubleshooting, has it bitten the dust?
Hello,
I have a Ryobi router that worked fine for a little while. (Bought it used) However now when I turn on the power switch the LED lights on the bottom turn on but the motor does not. After playing with it a bit I realized tapping the side of the router near the motor housing would sometimes get it to kick over. After doing this a few times even that would not work. However, if I tap the router on the edge of the table with some decent force it will turn over, sometimes I tap it several times before the motor will run on it's own. Once I get it going full speed it doesn't slow down or struggle. This makes me think this might be something simple to fix or replace. Any ideas? Thanks for your help in advance!
gogogadgetman77 is offline
post #2 of 15 (permalink) Old 12-10-2014, 01:44 PM
Hey, Sam; take it apart check the bearings, clean everything thoroughly, and replace the brushes...also blow air through the switch.
And stop banging on the damn thing; it's supposed to be a precision tool!
Oh, and welcome to the forum!
DaninVan is offline
post #3 of 15 (permalink) Old 12-10-2014, 01:59 PM
Originally Posted by gogogadgetman77 View Post
Hello,
see if this helps,,,
post #4 of 15 (permalink) Old 12-10-2014, 02:11 PM
If it is bearings you should be able to feel them when you spin the shaft by hand. It will be stiff and you would probably find some spots harder to turn past than others. If it is the switch you should see some sawdust drop out of it when you tap lightly on the side around the switch. This was a problem some Bosch routers had until the factory replaced them with one that wouldn't clog up.(Bosch sent them to all customers who had that model free of charge by the way.) Brushes have to be inspected to diagnose easily. Check the power cord while you're at it. If you get the router running lay it on its side and wiggle the cord around. If it runs normally when you get it running it likely is something simple.
post #5 of 15 (permalink) Old 12-10-2014, 03:49 PM
Nickp's Avatar
First Name: Nick
If we're starting a pool, I'm in it for the brushes...
Welcome...Nick
Nick
Nickp is offline
post #6 of 15 (permalink) Old 12-10-2014, 05:39 PM
Welcome...Nick
me too...
post #7 of 15 (permalink) Old 12-11-2014, 06:47 AM
First Name: Dennis
Yea- brushes have had similar experiences with other tools. Do they arc when it does run?
Dennis
Tough as nails and nearly as smart
Good tools don't cost- they pay!
64 ford is offline
post #8 of 15 (permalink) Old 12-11-2014, 07:31 AM
First Name: Buck
I'm with the brushes. It sounds like they might get hung up and so don't make contact. When you're banging the router that causes them to slip down and make contact. It could be that they are worn or the spring is tired or broken.
Buck
BOjr is offline
post #9 of 15 (permalink) Old 12-11-2014, 07:44 AM
BrianS's Avatar
First Name: Brian
Hi Sam. Welcome to our little corner of the 'net.
I'm thinking brushes as well. A very common wear point on older power tools, and usually a very cheap fix.
Brian
(Origin uncertain)
BrianS is offline
post #10 of 15 (permalink) Old 12-11-2014, 07:53 AM
CharleyL's Avatar
First Name: Charley
+1 more on the brushes. Now your decision is where to find replacements. Try eReplacements Premium Power . Another possibility is your local hardware store. If it's one of the better hardware stores, they will have many different sizes of "generic" brushes. Take one of yours with you to match up. If you don't find a perfect match, buy a pair that's close and sand or file them to get the right size. I've had to do this a few times and it works. Just keep in mind that the brush sanding dust is conductive, so clean up often and don't get the dust mixed with your electrical circuits.
Charley
Central North Carolina
CharleyL is offline
My Router Table Project (or, How Much MDF Dust Can I Create?) TeamTurpin Table-mounted Routing 14 12-09-2012 04:11 PM
Dust collection from router table barryaclarke Table-mounted Routing 6 12-09-2010 08:50 AM
Dust collection bottom of router barryaclarke Table-mounted Routing 1 11-13-2010 05:46 PM
