Cutting a "T" slot - Router Forums
post #1 of 13 (permalink) Old 12-13-2014, 06:20 PM Thread Starter
First Name: Harvey
Question Cutting a "T" slot
what is the safest and best method of routing a "T" slot in a picture frame. I have a 1/4 inch "T" slot bit and a Bosch trim router that would accommodate this bit. I am concerned about the ability to keep the router on track. The picture frame is too large to take to my router table.
harvmar is offline
post #2 of 13 (permalink) Old 12-13-2014, 06:34 PM
Welcome to the forum, Harvey.
I would look at a "ski" set up to maintain the level of the cutter.
How big is the frame and do you have work bench large enough for it to sit on?
PS: I have moved your post to another section of the forum.
Sydney, Australia
jw2170 is online now
post #3 of 13 (permalink) Old 12-13-2014, 06:36 PM
load a picture of the frame into your computer and then post a picture of the frame's profile...
point ot where you want the T slot...
post #4 of 13 (permalink) Old 12-13-2014, 06:42 PM
Marco's Avatar
What is the purpose of the T-slot in the frame? For hanging?
Galatians 5:13
Marco is offline
post #5 of 13 (permalink) Old 12-13-2014, 06:52 PM
Semipro's Avatar
First Name: John_*
Hello Harvey
Welcome to the forum.
Are you talking about a keyhole slot to hang the picture?
Thank You John
Semipro is online now
post #6 of 13 (permalink) Old 12-13-2014, 07:31 PM
old55's Avatar
First Name: Ross
Welcome to the forum Harvey.
Ross,
old55 is offline
post #7 of 13 (permalink) Old 12-13-2014, 09:24 PM
Welcome to the forum. The safest way is to plunge the bit in. With a trim router you would have to tip the bit into the cut. One big issue with using the keyhole bit is that it has to be in exactly the right spot or the picture will hang crooked which is why so many people use the sawtooth hangers that allow you to find the spot where it balances. If the frame is narrow you will need to add blocking on either side to keep the router stable.
post #8 of 13 (permalink) Old 12-14-2014, 08:13 AM
First Name: Keith
I always run my keyhole slot horizontal instead of vertical. That way you simply slide the picture until it hangs even. Space allowing, of course.
Keith Hodges is offline
post #9 of 13 (permalink) Old 12-14-2014, 10:32 AM
Everytime I used a "T' slot bit ,I broke it. I used to then cut a saw kerf and then followed with the bit, that seemed to work. What you are doing is a Key hole ,I think, and I wouldn't do them free hand without a template.
Herb Stoops is online now
post #10 of 13 (permalink) Old 12-14-2014, 02:28 PM
First Name: Lewis
Same here much easier then placing at exact spot
rockin cycle is offline
3/8" slot for cutting board joevm Router Bits - Types and Usage 5 05-13-2014 08:29 PM
slot cutting bit David2058 Router Bits - Types and Usage 28 12-23-2011 06:43 PM
Bit for cutting slot for Miter Track Racer2007 Table-mounted Routing 4 08-31-2011 11:01 PM
Slot cutting bit for luan plywood ccmnova Router Bits - Types and Usage 1 06-09-2011 05:24 PM
router bit meeting resistance cutting a slot??? matey Router Bits - Types and Usage 3 10-03-2005 05:30 AM
