Router for 200 - Router Forums
post #1 of 10 (permalink) Old 12-21-2014, 08:44 PM Thread Starter
First Name: Joshua
Send a message via Skype™ to Acts 8:37
Default Router for 200
Hello! Needing a new router. I would like a table but I might have to shop locally for that. I'm currently not good enough to build one yet. I do like Dewalt, but I often wonder if I'm not paying a little extra sometimes for the brand name. Any advice would be great! Thank you!
Oh, I would also like the plunge function.
Acts 8:37 is offline
post #2 of 10 (permalink) Old 12-21-2014, 08:59 PM
do yourself better...
Factory Reconditioned Bosch 1617EVSPK-RT 12 Amp 2.25 HP Combination Plunge and Fixed-Base Router Kit
post #3 of 10 (permalink) Old 12-21-2014, 09:39 PM
RainMan 2.0's Avatar
I'm with Stick on this one
That's one heck of a router for the price !
Ok ,I never insulate
RainMan 2.0 is offline
post #4 of 10 (permalink) Old 12-21-2014, 10:13 PM
First Name: Al
Hello! Needing a new router. I would like a table but I might have to shop locally for that. I' m currently not good enough to build one yet. I do like Dewalt, but I often wonder if I'm not paying a little extra sometimes for the brand name. Any advice would be great! Thank you!
A table can be as simple as a piece of discarded counter top,don't sell yourself short,instead tell yourself"I can do it"
al m is offline
post #5 of 10 (permalink) Old 12-21-2014, 10:25 PM Thread Starter
First Name: Joshua
I might try it Thanks for the encouragement!
post #6 of 10 (permalink) Old 12-21-2014, 10:38 PM
First Name: Al
Good for you,and take sticks advice,the bosch 1617 Evs is as good as it gets
al m is offline
post #7 of 10 (permalink) Old 12-22-2014, 09:16 AM
1617 reconditioned by Bosch is a terrific tool. I'm not much of a DeWalt fan anymore. Someone bought them out and I just don't like the build anymore. The Bosch also has an option to use its fixed base as a table mount that allows you to adjust the bit height from above the table. Table tops are pretty easy to make, but you'll probably want to buy an aluminum base, which requires routing out an opening with ledge first. You can do it, it will teach you a lot about routing in the process. Look up some of the plans on the site, and also look at some youtube videos of the process. Its the kind of project that gives you confidence AND skills. As to reconditioned, with Bosch you get like new.
post #8 of 10 (permalink) Old 12-22-2014, 10:01 AM
First Name: don
Dewalt tools are primarily made for the construction trades. If you are just starting out in woodworking and you can afford to buy the better brand tools, believe me, you will never regret doing so. As far as building a router table, if you can acquire a set of plans for "Norm Abrams-New Yankee Workshop" router table as I did some twenty years ago, you will never regret doing so. I still use mine from all these years ago---I am not a fan of all these new designs.
old woodworker is offline
post #9 of 10 (permalink) Old 12-22-2014, 01:45 PM
Phil P's Avatar
First Name: Phil
Hi Joshua
From what I've seen of prices that puts you just under the price tag of a DW621 (at circa $230 best price I can find). I have the almost identical DW622 (not sure if that's available in the USA, probably a Europe only model) and I'd recommend either because they are small and light whilst having the best dust extraction you'll get on a router at present, other than a Festool. There are a few minuses, as with every router; for example the base plate is a bit small so edge work is best done using an offset sub base (see Quillman's site for info on how he deals with this), but overall they are good examples of the type and if you can get the fence it is pretty good, too
As far as router tables go, a router table can be as simple as a piece of 3/4in plywood or melamine with the router screwed-on underneath and a piece of pine baseboard (skirting), a screw and a G-clamp for a fence. The DW621/DW622 require a fine depth adjuster to allow you to do this - these, together with the fence were bundled with mine when I bought it, but I don't know if that's the case in the USA. You can tell I'm a carpenter, but I've moulded I don't know how much material with a simple set-up like that. Not much to look at, but good enough to get you started. You can always build yourself a real humdinger of a table later, when you really know what you want.
Can't say how well or badly the Bosch compares. Fixed base routers aren't very popular over here so we don't really see them very often. Even Bosch sell about 95% plungers in this market
Regards
Phil
Phil P is offline
post #10 of 10 (permalink) Old 12-23-2014, 07:54 AM
CharleyL's Avatar
First Name: Charley
My first router table was a scrap piece of Formica covered 3/4" plywood that I got from a countertop installer (a kitchen sink cut-out). I squared up the rough cut edges and drilled holes in the center of it to mount a fixed base router. A 2 X 4 with one jointed edge and a notch for clearance around the router bit, held in place with C clamps was my router fence. I placed it between saw horses to use it and it worked quite well. I later built a stand for it out of 2 X 4 and used it for years that way.
It doesn't take much to make a pretty versatile, and cheap, router table.
Charley
Central North Carolina
CharleyL is offline
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
