Bosch MRF23EVS E-Clip - Router Forums
post #1 of 5 (permalink) Old 12-28-2014, 08:42 PM Thread Starter
First Name: Jack
Default Bosch MRF23EVS E-Clip
The e-clip on the Bosch MRF23EVS that holds the above the table adjustment rod keeps popping off, and I lose the ability to make height adjustments to the router. I have been trying to use 3/16" e-clips. I measure 13/32 with my caliper. No one in the area has that size. The diagrams on the parts list for the router does not show the size of the e-clip or even the rod. Does anyone know the correct size for this e-clip? Any suggestions?
hartjack is offline
post #2 of 5 (permalink) Old 12-28-2014, 09:02 PM
call Bosch CS and talk to them.. they are some good people and they will help you...
that clip is in millimeters... what ever it may be...
for some reason I think you either tried to adjust past the stops or didn't unlock the holding clamp 1st and you have bigger issues than a E clip that won't stay put...
post #3 of 5 (permalink) Old 12-29-2014, 06:23 AM Thread Starter
First Name: Jack
Default E-Clip
I evidently went beyond the range of the adjustment and popped the clip. The clamp was open.
hartjack is offline
post #4 of 5 (permalink) Old 12-29-2014, 01:05 PM
First Name: Earl
I've done it twice on my 1617--after the second time i taped a pair of spares near. Haven't done it since.
earl
greenacres2 is offline
post #5 of 5 (permalink) Old 01-05-2015, 08:19 AM Thread Starter
First Name: Jack
I replaced the e-clip with a 1/4" shaft collar. It fits perfectly and appears to be more stable than the e-clip. The router has the full range of adjustment.
hartjack is offline
Shaft wrench for Bosch 1617EVS nn4jw Table-mounted Routing 9 02-17-2014 09:06 AM
Suggestions for Bosch router for table use Mr.Maim Table-mounted Routing 12 07-31-2013 04:39 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch 1617EVSPK or Bosch 1619EVS LBrandt Table-mounted Routing 25 01-19-2012 09:44 AM
Dewalt or Bosch??? jrwoodbutcher Starting Off 5 12-23-2010 10:18 AM
