Why is the Bosch MRC23EVSK rated at 2.3 hp? - Router Forums
post #1 of 12 (permalink) Old 01-01-2015, 08:22 PM Thread Starter
TWheels's Avatar
Default Why is the Bosch MRC23EVSK rated at 2.3 hp?
The Bosch MRC23EVSK, which comes as a motor, plunge base and fixed base, just like all the 2-1/4 hp routers with which I am familiar, differs from the 2-1/4 routers in that it is rated at 15 amp like all the 3-1/4 hp routers. All other 2-1/4 hp routers are rated at 11 amp.
Is it an horrendously inefficient motor, a typo propagated prolifically or is there some other explanation?
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #2 of 12 (permalink) Old 01-01-2015, 08:31 PM
according to tech support...
newer more efficient motor...
post #3 of 12 (permalink) Old 01-01-2015, 09:50 PM
Maybe Bosch decided to post a power rating that was a little more honest than everyone else. Compare the 15 amps to the other manufacturer's 15 amp motors Tom.
post #4 of 12 (permalink) Old 01-01-2015, 11:04 PM
First Name: Al
Honesty in hp rating..
That's refreshing
al m is offline
post #5 of 12 (permalink) Old 01-01-2015, 11:04 PM Thread Starter
TWheels's Avatar
Charles, your suggestion makes a lot of sense. If we take volts x amps = watts, and convert that to hp, for 15 amp, 120 volt it is 2.4 hp. A 3.25 hp motor at 120 volts would require over 20 amps.
Thanks very much.
TWheels is offline
post #6 of 12 (permalink) Old 01-01-2015, 11:09 PM Thread Starter
TWheels's Avatar
Stick, your attachment seems to me to indicate the motor is less efficient, and everything I can find indicates the MRC23EVS is a newer model than the 1617EVSPK. So I am left more confused.
TWheels is offline
post #7 of 12 (permalink) Old 01-02-2015, 07:04 AM
tvman44's Avatar
First Name: Bob
Hp is a numbers game manipulated by the sales dept IMHO.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #8 of 12 (permalink) Old 01-02-2015, 07:40 AM
There isn't much that is in that article that I agree with. In my opinion, rpm is more a measure of stored energy. Even he admitted that universal motors lose it quickly. Whenever you use a router you hear it slow way down as soon as you start cutting and I think the manufacturers are calculating something more along the lines of stall or brake horsepower which is how much force is required to bring it to a stop once you wind it up all the way. This only measures power over a very short interval and has absolutely nothing to do with the actual amount of work the tool is capable of.
If they were really honest they would post input watts and the efficiency rating or the actual output watts which is the same thing. That will give you a much better idea of how much work you can do with the tool. Without the actual rating your best bet is to just match the amp draw from one tool to the next. Most of the better names will be similar as far as efficiency goes so the rest of the decision is how do you like the machines features and how does it feel in your hands?
post #9 of 12 (permalink) Old 01-02-2015, 09:55 AM
Honored Member
First Name: pat
VS tools are supposed to maintain their speed and power under an ordinary or instantaneous over load.
To do that they need more current on demand.
The VS circuitry does just that. As such, they are rated higher and can stand the electrical stress without burning out. It is not theatricks.
Quillman is offline
post #10 of 12 (permalink) Old 01-02-2015, 10:05 AM
First Name: Duane
If that's the case, why not correct the published ratings of their other routers?
Dmeadows is offline
Bosch trigger activated MRC23EVSK fail - mpIX General Routing 0 06-03-2013 05:50 PM
Router Boss and MRC23EVSK 2.3 HP Bosch newinwood Jigs and Fixtures 0 01-04-2013 04:57 PM
Quick Review Bosch MRC23EVSK Modular Router System jgt1942 General Routing 3 12-15-2012 08:40 PM
Bosch MRC23EVSK with free RA1054 edge guide achoox4 General Routing 4 12-03-2012 04:38 PM
For Sale: Bosch MRC23EVSK Kit NIB Pirate Woodworking Classifieds 2 04-25-2011 06:52 AM
