Sticky collet - Router Forums
post #1 of 12 (permalink) Old 01-02-2015, 05:38 PM Thread Starter
First Name: Jerry
Question Sticky collet
I have owned my Makita M12 /3.5hp plunge router for 7 or more years, and like its power and ease of plunge height adjustment. Mine is mounted in a Veritas (Lee Valley) steel surface router table. It has a home-made crank for height adjustment, and while only a single-speed model, works well through a plug-in speed controller. The only real complaint I have is that the bit is difficult to remove after use. The nut is not over-tightened, and the collet and inside shaft are rust-free, but sometimes it requires loosening the nut entirely then tapping the bit and collet with a piece of hardwood and a mallet. I've also tried using a bronze-phosphor brush to clean inside the shaft; used 800 or 1000 grit wet and dry paper to polish; ensured that there are no burs on the bit shank; even put a drop of light oil on the bit shank prior to insertion. Yet the same damned problem remains. Any solutions out there? (And no, I'm not going to replace the router).
jervic is offline
post #2 of 12 (permalink) Old 01-02-2015, 05:53 PM
Semipro's Avatar
First Name: John_*
Hello Jerry welcome to the forum.
Thank You John
Semipro is offline
post #3 of 12 (permalink) Old 01-02-2015, 06:19 PM
new collet...
good chance yours has been torqued...
polish the collet seat w/ rouge compound...
some reading on collets...
post #4 of 12 (permalink) Old 01-02-2015, 06:57 PM
Hi Jerry, welcome to the forum.
Sydney, Australia
jw2170 is offline
post #5 of 12 (permalink) Old 01-02-2015, 07:07 PM
Welcome to the forum Jerry.
post #6 of 12 (permalink) Old 01-02-2015, 08:44 PM
old55's Avatar
First Name: Ross
Ross,
old55 is offline
post #7 of 12 (permalink) Old 01-02-2015, 10:12 PM
First Name: Al
hi Jerry and welcome
High probability that Stick is right
But just in case we are overlooking the obviouse, your not bottoming out the bit in the collet,are you?
al m is offline
post #8 of 12 (permalink) Old 01-03-2015, 12:22 AM
RainMan 2.0's Avatar
Ok ,I never insulate
RainMan 2.0 is online now
post #9 of 12 (permalink) Old 01-03-2015, 07:43 AM
First Name: Gary
Jerry, Some collet nuts are heavier (more mass) than others. If the router is turned on the nut will tighten down by centrifical force and if there is no bit installed, it could damage the collet permanantly.
gmercer_48083 is offline
post #10 of 12 (permalink) Old 01-03-2015, 10:35 AM
GregLittleWoodworks's Avatar
First Name: Greg
Hello Jerry,
I went through this same exact problem with the exception of it happening on a Milwaukee router. It got so frustrating that I bought a new collet and still had the same problem and ended up shelving the router for a while. After rereading some info here about the Musclechuck I replaced the Milwaukee collet with a Musclechuck and it has worked flawlessly and so easy to change bits. I ended up buying two more Musclechuck collets for the table routers.
“Each step of every Wood Art project I design and build is considered my masterpiece… because I want the finished product to reflect the quality and creativeness of my work. I study each piece to get ideas and details that will evolve in my future creations.
GregLittleWoodworks is offline
Freud FT2200 1/4 collet - help. Maverick81 Freud 1 09-28-2013 03:44 PM
MY PC 7518 collet was junk, I replaced it with a Precision Collet what a difference. Bill Huber General Routing 0 09-25-2012 11:52 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Sticky collet. ammy Starting Off 17 10-05-2009 01:29 AM
Sticky Collet gbnevard Tools and Woodworking 6 01-28-2005 05:37 PM
