Flush Trimming Edge Banding - Router Forums
post #1 of 7 (permalink) Old 01-07-2015, 04:40 PM Thread Starter
Contributor of the Month
Default Flush Trimming Edge Banding
I've seen different methods for flush trimming edge banding. Tall fence on router table, 2 side by side pieces to support router when hand trimming. With a mid-sized router what is the minimum width of edge banding that could safely support the router if there was not a second piece to provide support? Specifically, would edge banding 2" wide be wide enough to support a mid-size router?
JIMMIEM is offline
post #2 of 7 (permalink) Old 01-07-2015, 04:47 PM
yes....
post #3 of 7 (permalink) Old 01-07-2015, 04:53 PM Thread Starter
yes....
Thank You. That's the answer I was hoping for.
JIMMIEM is offline
post #4 of 7 (permalink) Old 01-07-2015, 05:07 PM
clamping may be an issue...
pay close attention to what you are doing...
lay two pieces side by side and increase the foot print...
post #5 of 7 (permalink) Old 01-07-2015, 05:55 PM
Honored Member
First Name: pat
You can modify a subbase for this function.
Then proudness nor width is an issue.
Moreover, the router is safer on terra-firma, flat.
Quillman is offline
post #6 of 7 (permalink) Old 01-07-2015, 10:18 PM
The method for a router table is really simple if you can do it that way.
post #7 of 7 (permalink) Old 01-08-2015, 06:35 AM
Country: South Africa
First Name: Denis
I agree with an earlier post - a router table with a tall fence is the way to go (provided the workpiece is not too large).
Note that when using a handheld router with a flush trim (bottom bearing) bit the cut is forgiving (see proviso below) . If you tip the router downwards it pivots on the bearing leaving a bump in the trimmed edge. This can be removed on a second pass.
The forgiving doesn't happen if you tilt the router upwards.
denis lock is offline
Flush trimming on router table SRVDVM Table-mounted Routing 2 11-04-2013 02:11 PM
edge banding spidennis Router Bits - Types and Usage 10 05-07-2013 09:24 AM
My flush trimming split my workpiece ScoFF General Routing 10 08-12-2011 04:16 PM
flush trimming 3/4" and 1" mdf z399y General Routing 8 05-09-2010 01:09 PM
