Rigid 2900 collet issue... - Router Forums
post #1 of 12 (permalink) Old 01-05-2015, 07:48 PM Thread Starter
Default Rigid 2900 collet issue...
I've not found exactly how to change the collets out from the manual. I put the 1/4" collet in the 1/2" collet tighened it and did my routering. Problem, I couldn't remove the bit, first of all without dismantling the base and having to manhandle bit with a vice grip and then, the collet came out with a snap clip that came free. I've now a new collet.... but what is the proper means of installing the 1/4" collet in this router?
Aloha,
Tom
Rattus58 is offline
post #2 of 12 (permalink) Old 01-10-2015, 07:42 AM
Nickp's Avatar
First Name: Nick
Aloha,
Tom
Tom...you will probably want to move this question to the appropriate area but...I have the same router and collets...is it possible that after routing you loosened the collet and didn't go past the second loosening...? The collet will break free, keep going and it will appear tight again...keep going and the bit will be freed... Might this be what happened...?
Nick
Nick
Nickp is online now
post #3 of 12 (permalink) Old 01-12-2015, 02:44 PM Thread Starter
Nick
Pretty much, but the effort to extract it was to the point of being susceptible to personal injury.... the 1/4 inche just drops into the 1/2 inch am I right?
Aloha,
Tom
Rattus58 is offline
post #4 of 12 (permalink) Old 01-13-2015, 12:23 AM
Semipro's Avatar
First Name: John_*
Tom are talking about a 1/4" sleeve to hold bit in a 1/2" collet?
If so line up the 1/4" sleeve slot with one of the 1/2" collet grooves
Semipro is offline
post #5 of 12 (permalink) Old 01-13-2015, 06:22 AM
Nickp's Avatar
First Name: Nick
Tom...the 2900 comes with two separate collets ... 1/2 and 1/4 ... No need for adapter. Are you using a separate 1/4 adapter with the 1/2 collet...?
Nick
Nickp is online now
post #6 of 12 (permalink) Old 01-18-2015, 11:53 PM Thread Starter
When I bought my Ridgid it came with the 1/2 collet and a another collet that was about 1/2" an inch. The only way I could see it working was to fit it within the 1/2" collet, which did work for a bit. Two things from there happened, one I couldn't extract my router bit and two, I couldn't get the collet out. I broke the retaining spring for the 1/2 collet and without thinking about it all, ordered another one thinking it the problem... and, sadly, it's not. I went and bought a cheap sears plunge router, but it is not the same nearly as the Ridgid, but it too has both 1/2 and 1/4 collets and they are two separate pieces that screw in to the collet housing.
I'm tempted to order a 1/4" collet from Ridgid/Ryobi, but they are expensive with shipping to Hawaii...
I've tried lining up the slots and once cinched down... the problem persists.
Thank you for trying to help out, I'm new at this.
Much aloha,
Tom
Rattus58 is offline
post #7 of 12 (permalink) Old 01-19-2015, 09:07 AM
Nickp's Avatar
First Name: Nick
Tom...is this what you have (2 complete assy's) or do you have the 1/2 with an adapter that slides into the 1/2 inch...?
Note that either one is a complete assembly made up of a collar nut and either 1/2 or 1/4 bit holder. Neither of these are intended to come apart if that is what you might be doing.
The 1/2 inch can accept an adapter to accept 1/4 inch bits. In that case the original 1/2 squeezes the adapter to squeeze the bit.
Do you have bit cleaner that you could soak the assembly in...then blow it out with air hose...?
Nick
When you open the image it will be right side up.
Nick
Nickp is online now
post #8 of 12 (permalink) Old 01-26-2015, 12:51 PM Thread Starter
Nick
No... I have the 1/2 and a little collet like on a dremel, that fits in it.... I don't have the nut and collet. Is that what I need? Are they available anywhere?
Much Aloha,
Tom
Rattus58 is offline
post #9 of 12 (permalink) Old 01-26-2015, 01:09 PM
Nickp's Avatar
First Name: Nick
I would recommend contacting Ridgid and asking them if the 1/4 inch collet assembly is available. Is your 1/2 inch collet assembly in good shape...?
my usual source of parts, ereplacementparts.com, shows the collet assembly "discontinued"...
...an aside question...when you insert the 1/4 inch shaft bit into the adapter, do you put it all the way in or back it out about 1/8"...?
...second question...did you get the adapter with the router or is it after-market or borrowed...?
Nick
Nick
Nickp is online now
post #10 of 12 (permalink) Old 01-26-2015, 01:39 PM
Nickp's Avatar
First Name: Nick
Tom...one more item...
Published part numbers have changed...
Good Part Numbers...not obsolete...
672036001....1/4 inch collet assembly
201389001....1/2 inch collet assembly
513349001....1/2 inch to 1/4 inch adapter
Nick
Nick
Nickp is online now
Triton in table - collet quesion JP Wolf New Member Introductions 6 08-17-2014 09:28 PM
Freud FT2200 1/4 collet - help. Maverick81 Freud 1 09-28-2013 03:44 PM
Rigid 2900 Variable speed bypass jimander General Routing 0 10-06-2012 10:24 AM
MY PC 7518 collet was junk, I replaced it with a Precision Collet what a difference. Bill Huber General Routing 0 09-25-2012 11:52 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
