dewalt 625 - Router Forums
post #1 of 5 (permalink) Old 01-12-2015, 01:47 PM Thread Starter
First Name: jonathan
Default dewalt 625
I broke the fence on my dewalt 625, it has 10mm rods spaced at 100mm centres, the makita 193312-9 fence looks a lot better quality, does any one know the dimensions of the rods & centres of the makita, or a website that gives the dimensions, from jonathan
sweep96 is offline
post #2 of 5 (permalink) Old 01-12-2015, 07:18 PM
old55's Avatar
First Name: Ross
Jonathan I'm sure someone will be along to give you a hand.
Ross,
old55 is offline
post #3 of 5 (permalink) Old 01-13-2015, 03:23 AM
Phil P's Avatar
First Name: Phil
Hi Jonathan
There are two different fences available for the DW625. The all-alloy one doesn't take too kindly to being dropped (when attached to the router, that is - I doubt that any ally fence does), but other than that it is pretty durable in my experience. I've still got an Elu MOF177e from the mid-1980s with the original ally fence. The DW steel and alloy composite fences (identical to that sold with the DW621/DW622 over here) is more durable, but I don't think it's such a good fence. I have broken only one DW625/MOF177e fence in 30-odd years and that was after several trips to a concrete floor (the joy of site work!)
I know that the cast alloy fences from the Bosch GOF2000ce and GOF1300ce are compatible with the DW621/DW622/DW624/DW625/DW626, but I can't say for the Makita fences. Looking at the Mak fence in photos it doesn't really seem any better/stronger than the DW one (of which it is seemingly a copy), and it seems to be a lot more expensive than a replacement DW part (at circa £25 - although you can sometimes get the full fence with rods for little more o eBay). The only Makita replacement I can find in the UK under the part number you quote is the steel type which is comparible with the DW steel type - but a lot more expensive - so if you do go Makita I'd be careful to check what you're getting.
Regards
Phil
Phil P is offline
post #4 of 5 (permalink) Old 01-13-2015, 05:00 AM Thread Starter
Thanks Phil, i will check them out
sweep96 is offline
post #5 of 5 (permalink) Old 02-02-2015, 12:48 PM Thread Starter
I glued the fence together with gorilla glue & glued a formica top on the fence & it worked
sweep96 is offline
Stuck Collet Dewalt 625 ogee General Routing 12 11-10-2018 10:56 AM
For Sale: New Woodrat Kit and DeWalt 625 Router relyk Woodworking Classifieds 4 04-18-2012 01:31 PM
Dewalt 625 base plate Giacomo New Member Introductions 4 01-04-2010 02:56 AM
Dewalt DW 615 or 621 or 625 Laurie Saunders General Routing 8 06-24-2009 11:36 AM
Dewalt 625 issues and questions Greg_R General Routing 9 12-11-2007 04:16 PM
