1/4 inch cove and bead bit - Router Forums
post #1 of 8 (permalink) Old 01-17-2015, 08:39 AM Thread Starter
First Name: Warren
Default 1/4 inch cove and bead bit
I'm starting a clock project that calls for a 1/4 inch cove and bead bit. I have found several different cove and bead bits, but not a quarter inch. Maybe it is my lack of routing experience. Where can I find a 1/4 inch cove and bead bit? I figure I am probably seeing them and I just don''t know what i'm looking at.
Thanks in advance.
ExpressEN1 is offline
post #2 of 8 (permalink) Old 01-17-2015, 08:52 AM
Thanks in advance.
this is what you are looking for...
Whiteside Router Bits 3210 Cove and Bead Bit with 1/4-Inch Radius, 1-5/16-Inch Large Diameter and 5/8-Inch Cutting Length - Cove Router Bits - Amazon.com
post #3 of 8 (permalink) Old 01-17-2015, 08:53 AM
john60's Avatar
Default http://www.rockler.com/rockler-bead-cove-bits-for-canoe-building
Bead & Cove Canoe Building Router Bits | Rockler Woodworking & Hardware
john60 is offline
post #4 of 8 (permalink) Old 01-17-2015, 09:01 AM
Thanks in advance.
here's another..
BTW.. both brands are very good bits...
http://www.amazon.com/Freud-38-524-2...N%3DB00004T7H5
post #5 of 8 (permalink) Old 01-17-2015, 09:55 AM Thread Starter
First Name: Warren
Thanks for the quick replies. I was right, I was looking at the correct bits but didn't know it.
post #6 of 8 (permalink) Old 01-18-2015, 12:28 PM
If you want a 1/4" (dia.) bead you get an 1/8" radius bit.
Herb Stoops is online now
post #7 of 8 (permalink) Old 01-19-2015, 07:57 PM
Garyk's Avatar
First Name: Gary
For really small stuff Amana makes a set, mostly for modeling. Not what you reffered to just throwing that out there.
Garyk is offline
post #8 of 8 (permalink) Old 01-19-2015, 08:04 PM Thread Starter
First Name: Warren
I found the bit at Lowes of all places. Thanks
cove bead salukiraptor Router Bits - Types and Usage 5 08-22-2014 10:20 PM
large-ish (0.5" - 1" radius) bead & cove / flute and bead bits carl0s Router Bits - Types and Usage 8 01-07-2013 10:11 AM
Cove and Bead cutters ? Steve. B. New Member Introductions 1 01-26-2008 02:43 AM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
