New base - Router Forums
post #1 of 16 (permalink) Old 01-26-2015, 09:18 AM Thread Starter
First Name: Dale
Default New base
I want to make a clear base for my DeWalt 611R. I have a sheet of Lexan about 1/8" thick I would like to use. I will have to make it at least double or triple thick. My question is can I do this or should I buy the thickness I need? What type of glue should I use and still be able to see through the lexan base and not worry about it coming apart?
Thanks for any help.
Dale
Dale69 is offline
post #2 of 16 (permalink) Old 01-26-2015, 09:27 AM
Nickp's Avatar
First Name: Nick
Welcome, Dale...
I would suggest getting the thickness you want, 3/8 apparently...save the 1/8's for another project. Use the original base as a model...and don't forget to make sure it is concentric with the bit.
Nick
Nick
Nickp is online now
post #3 of 16 (permalink) Old 01-26-2015, 12:42 PM
Semipro's Avatar
First Name: John_*
buy new
Semipro is offline
post #4 of 16 (permalink) Old 01-26-2015, 01:25 PM
Dale
if the new base is the same size as the one on the router 1/4'' polycarbonite is more than adequate...
post #5 of 16 (permalink) Old 01-26-2015, 03:30 PM
PhilBa's Avatar
First Name: phil
+1 for 1/4" polycarbonate (aka lexan). I have made a number of specialty bases for my various routers out of 1/4" lexan (which is actually something like .238"). Works great. easy to machine, cut, drill, route.
PhilBa is offline
post #6 of 16 (permalink) Old 01-26-2015, 04:43 PM
Honored Member
First Name: pat
Definitely do not glue or screw the thin stock.
And if you need one ready for work.
Quillman is offline
post #7 of 16 (permalink) Old 01-26-2015, 06:09 PM
RainMan 2.0's Avatar
A small piece of 1/4" lexan shouldn't be very much money . I go to glass shops and they always have odd pieces you can buy . I paid 100 bucks for a piece of 1/2" lexan that would normally be 400 because it was an odd width and length
RainMan 2.0 is offline
post #8 of 16 (permalink) Old 01-27-2015, 07:30 AM
First Name: Ron
Dale, go with Pat Warner's (Quillman) bases, precision made, oversized, better control/stability, reasonable price & quick shipping...have two and will be ordering more as needed. Much better than the DW supplied bases. Use 'em on my DW618.
rpludwig is offline
post #9 of 16 (permalink) Old 01-27-2015, 08:37 AM
First Name: Gary
Dale, I use two 1/8" sandwiched. One with a larger hole to accept brass guides. It works well. I use a cone with a centered 1/4" pin to center the base when I tighten the screws to make the base, then remove the cone. This method works good for me. Fast and accurate. It even works good on my large plunge router.
gmercer_48083 is offline
post #10 of 16 (permalink) Old 01-27-2015, 10:20 AM
First Name: Ellery
+1 on Pat Warner's bases, etc. Quality, precission, grear customer service, whats there not to like!
Arcola60 is offline
Bosch plunge router base problem gwizz General Routing 20 03-16-2017 07:02 PM
Bosch MR 23 and Milescraft Turnlock base? achoox4 Guide Bushings and Templates 9 04-10-2013 05:48 AM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 07:54 PM
