Craftsman 315.25070 router - is it 1/4" or 1/2"? - Router Forums
post #1 of 6 (permalink) Old 01-29-2015, 02:10 AM Thread Starter
Default Craftsman 315.25070 router - is it 1/4" or 1/2"?
Hi
Newbie question..
Just looking at a well looked after old Craftsman router 25070 model and was wondering if it is just 1/4" or can it take 1/2" shafts?
And excuse my ignorance but why are there two different width shafts in routing?
thanks.
Paraic
paraic is offline
post #2 of 6 (permalink) Old 01-29-2015, 03:20 AM
old55's Avatar
First Name: Ross
Welcome to the forum Paraic.
Ross,
old55 is offline
post #3 of 6 (permalink) Old 01-29-2015, 07:24 AM
mgdesigns's Avatar
First Name: Mark
Originally Posted by paraic View Post
Hi
Newbie question..
thanks.
Paraic
http://vintagemachinery.org/pubs/222/4638.pdf
Judging from the parts breakdown, I'd say it's probably only 1/4" diameter bit capable. The reason for larger bit diameters is due to the size of bit (overall outside diameter) larger ones require larger shanks on the bits, to prevent the bit from shearing off during routing. Larger bits are much stronger, and can withstand the side load forces more adequately without flexing or breaking. That should be a good router for the general stuff, but you may want a more powerful router with removeable collets for the bigger projects.
Mark Greenbaum
CAD & 3D Designs
Custom Hand Engraving
Maker of Fine Kindling
mgdesigns is offline
post #4 of 6 (permalink) Old 01-29-2015, 07:35 AM
First Name: Duane
Hi
Newbie question..
thanks.
Paraic
Yep, 1/4" on the old Craftsman router.
Why 2 shank sizes? Actually, there are several out there... both SAE and Metric!
Dmeadows is offline
post #5 of 6 (permalink) Old 01-29-2015, 10:12 AM
I have bits in shank sizes 6mm, 1/4", 3/8", 10mm, 12mm, and 1/2". And there are a lot more than that. Lots of CNC straight bits are the same size as the diameter and they use collets for each size, so if you are buying bits online it's a good idea to make sure what the shank size is.
post #6 of 6 (permalink) Old 01-29-2015, 11:13 AM Thread Starter
Hi all
Thanks for the prompt and informative replies. I will go with this router for now to learn the ropes. It comes with the metal router table and is $50 with a few accessories and a bunch of 1/4 in bits. Good value I believe.
Paraic
paraic is offline
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-20-2014 12:41 AM
So you want to buy a router table... BobandRick Table-mounted Routing 39 08-30-2010 06:23 AM
Craftsman Tablesaw with Router wing rjhanby Table-mounted Routing 1 08-27-2009 12:10 PM
