dw610 sub base screws - Router Forums
post #1 of 5 (permalink) Old 02-02-2015, 08:53 PM Thread Starter
First Name: Nate
Default dw610 sub base screws
I just purchased a dw610 off of ebay. It did not come with the sub base or the screws to attach it. I guess I will order a replacement sub base, but I don't know what screws to use. The DeWalt part diagram simply calls them "SCREW,SELF TPG." but the B&D 3310 manual says "#8-32 x 5/16 Binding Hd. Screw"
Does anyone know the proper size for those screws? Thanks.
MartianMambo is offline
post #2 of 5 (permalink) Old 02-02-2015, 09:07 PM
I'm not home or I could measure them for you. I suspect they are metric because I have measured the shaft for the collet nut and it's metric. It's a good little router.
I won't be home for 10 more days but if you can wait I'll measure the diameter, thread pitch, and length.
post #3 of 5 (permalink) Old 02-02-2015, 10:09 PM
Honored Member
First Name: pat
They're called tri-lobals.
And they were self tapping.
But they're 8/32 x ~3/8" pan head slotted.
Need a collar plate?
Quillman is offline
post #4 of 5 (permalink) Old 02-03-2015, 06:55 AM
First Name: frank
I have had similar issues...I took the problem to my local ACE hardware and matched the screws I needed.......works every time!
frankr4ever is offline
post #5 of 5 (permalink) Old 02-03-2015, 08:45 AM Thread Starter
First Name: Nate
Chuck - thanks for the quick reply.
Pat - I came across your website when I was searching for info on the screws. Probably going to shoot you an email.
Frank - That was my thought as well.
Bosch 1617 router base problem bill kay General Routing 35 05-30-2016 08:39 AM
7518 router does not move freely in fixed base tgneid Tools and Woodworking 6 09-05-2011 09:24 AM
DIY Base Plate and Table bcskinz DIY and Renovation 7 03-25-2010 10:32 AM
Screws won't fit Router Plate don1 General Routing 24 02-16-2009 05:29 PM
Converting fixed base to plunge base. -Sam- Portable Routing 4 09-30-2004 03:53 PM
