Time to upgrade - Router Forums
post #1 of 13 (permalink) Old 02-05-2015, 01:59 PM Thread Starter
First Name: Phil
Default Time to upgrade
I currently own 2 pretty old routers. One is a Craftsman plunge router and the other is a Ryobi that I have mounted in a table I built years ago from plans in Shopnotes magazine.
I am actually looking to upgrade to a more powerful unit, mainly to be used in the cabinet. I have a short list of things I consider must haves but I have not found the exact combination yet. I figure with the vast knowledge of the members here, a lot of you will have suggestions for units i should consider.
Here are what I would ideally like to have on my new router in no particular order:
Both 1/4" & 1/2" collet capacity
Spindle lock
variable speed
soft start
plunge and fixed bases
minimum 2 HP
Above table height adjustment capability
With all that in mind, what say you?
Any and all suggestions are welcome and greatly appreciated.
Crustyoldcurmudgeon is offline
post #2 of 13 (permalink) Old 02-05-2015, 03:35 PM
There are a few that fit your description. Bosch 1617 combo will be the one most suggested.
post #3 of 13 (permalink) Old 02-05-2015, 03:56 PM
Bosch 1617EVSPK or MRC23EVSPK
post #4 of 13 (permalink) Old 02-06-2015, 08:49 AM
chessnut2's Avatar
Welcome, Phil. the Bosch 1617EVSPK is on sale at Lowe's this month for $30 off ($189). Jim
chessnut2 is offline
post #5 of 13 (permalink) Old 02-06-2015, 11:31 AM
I also suggest the 1617 EVSPK kit, and $189 is a steal. However, it does not have a spindle lock, you use two wrenches. There is a newer model Bosch that has a spindle lock and a built in LED light. It is MRC23EVSK, but is is about $269 on Amazon. It is pretty much the same as the 1617, so the extra $80 is the premium for those two features. It is essentially the same as the 1617. Every Bosch tool I own is terrific.
DesertRatTom is online now
post #6 of 13 (permalink) Old 02-06-2015, 01:41 PM Thread Starter
First Name: Phil
Seems like the Bosch 1617 has quite a loyal following. The lack of spindle lock isn't a deal breaker for me. I actually have a Lowe's right up the street from my office so I will go by after work and take a look. I read some reviews and looked over the specs. It looks like this may be the "route(r)" I decide to take.
Thanks to all for the feedback.
post #7 of 13 (permalink) Old 02-06-2015, 01:45 PM Thread Starter
First Name: Phil
Thanks for that tip. I like saving money.
Do you suggest buying the additional RA1165 Base to leave in my router table?
post #8 of 13 (permalink) Old 02-06-2015, 02:42 PM
chessnut2's Avatar
It comes with a fixed and a plunge base. Turn one handle, and you can remove the motor and put it into the other base. Turn that handle, and it's ready to use.
post #9 of 13 (permalink) Old 02-06-2015, 03:06 PM
MT Stringer's Avatar
Hello Phil. I have a pair of the 1617's. One is in a fixed base under my router table. I have the second one set up in a plunge base for cutting half blind dovetails (for drawer boxes).
I have also use the router to cut raised panels for cabinet doors. It is a big cutter, but I run the router at it's slowest speed and make several passes. No problem.
Bosch 1617EVSPK Combo
Good luck.
Name:	2014-09-18 15.14.13.jpg
Name:	2014-09-18 15.14.20.jpg
Name:	2014-09-19 13.11.54.jpg
Name:	2014-09-19 13.12.14.jpg
Name:	2013-10-15 19.51.52.jpg
Name:	2013-10-15 21.44.19.jpg
Name:	2013-10-18 15.22.45.jpg
Name:	2013-10-23 17.16.36.jpg
Name:	2013-11-04 17.04.38.jpg
MT Stringer is offline
post #10 of 13 (permalink) Old 02-06-2015, 05:55 PM
First Name: Ken
Phil, if you haven't bought it yet, check with your LOwes if you are a veteran. Lowes and HD give a 10% discount to veterans and active duty. In some areas it is available all the time, and in others, only or certain holidays. You could save even more on that router.
kklowell is offline
How Do You Spend your free time? smayragrace Lobby 32 01-07-2015 03:57 AM
Time to start thinking about Christmas presents RLego General Routing 7 07-16-2012 01:51 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
one time poly ? pemdas86 The Finishing Touch 10 08-02-2010 12:45 PM
Time to introduce myself thumpik New Member Introductions 8 09-16-2008 06:15 AM
