anyone know what this is? - Router Forums
post #1 of 13 (permalink) Old 02-05-2015, 03:12 PM Thread Starter
newfie2's Avatar
First Name: Todd
Default anyone know what this is?
My neighbor gave this but i'm not sure what its used for i know it for routering letters but have know clue how to set it up or even if it is all there.i use a pantograph for sign making but not sure what this is all about.sorry about the picture quality didn't realize the camera lens was steamed up a bit.
newfie2 is offline
post #2 of 13 (permalink) Old 02-05-2015, 03:40 PM
Phil P's Avatar
First Name: Phil
Could it be a device for using a router to douse for water, Todd?
Phil P is offline
post #3 of 13 (permalink) Old 02-05-2015, 04:06 PM Thread Starter
newfie2's Avatar
First Name: Todd
LOL u could be right on with that one.
newfie2 is offline
post #4 of 13 (permalink) Old 02-05-2015, 04:16 PM
First Name: walker
...this is like that what is it segment on "Ask this old house". Maybe they would know?
walkerrosewood is offline
post #5 of 13 (permalink) Old 02-05-2015, 05:04 PM
seen that before...
early sears pantograph or the arm for a ellipse jig...
I believe you are missing some of it...
post #6 of 13 (permalink) Old 02-06-2015, 08:12 AM
First Name: Gary
Todd, From the picture it has a pivot joint where the left arm joins the router base. The way I see it... It looks like a pantograph, where peg in the slot would slide as you use it allowing the pivot joint to change position. On the left arm there is an adjustable sharp peg that you stab into a base made of plywood, then as you move the stylis (at the end of the lower right rod) over your picture or letter the router would reduce the size as it cuts. The size would be determined by which peg hole the sharpened peg is in. I saw a pantograph similar to this demonstrated at a wood show sponsored by peachtree. OR... I could be WRONG!
gmercer_48083 is offline
post #7 of 13 (permalink) Old 02-06-2015, 08:41 AM
My first thought was pantograph too and like Stick, I think I've seen it before. What's throwing me is the circle in the middle but I'm starting to think maybe a Dremel type machine attaches there which would make it more of an engraver?
post #8 of 13 (permalink) Old 02-06-2015, 11:12 AM
TenGees's Avatar
First Name: Paul
I agree that something could be missing or it's not configured correctly. That cross-member wouldn’t be that long (to the right) if it was only a brace. It does look like a pantograph or engraver gizmo though.
TenGees is offline
post #9 of 13 (permalink) Old 02-06-2015, 12:51 PM Thread Starter
newfie2's Avatar
First Name: Todd
it is some sort pantograph but i have know idea how it works or if its all there.the person that gave it to me said it was all there except the letter templates. i think its just junk at this point!
newfie2 is offline
post #10 of 13 (permalink) Old 02-07-2015, 08:47 AM
First Name: Gary
Todd, A router sets on the casting and the 2 clamps hold it to the base. I would clamp a piece of plywood onto the casting that has a hole for a pencil, then play with it to figure it out.
