Bosch Router Kit Question - Router Forums
post #1 of 17 (permalink) Old 02-07-2015, 09:55 PM Thread Starter
First Name: lee
Default Bosch Router Kit Question
There seems to be multiple versions of the Bosch 1617 router kits. I was looking at the Lowes’s version to buy when I found this Bosch 1617EVSTB version. This version seems to come with the fixed base and a router base adjustable from the top. Would this be a better Bosch router kit to buy if you are going to run the router in a Bosch router table or another router table? I am trying to figure out what to buy.
coxhaus is offline
post #2 of 17 (permalink) Old 02-07-2015, 10:15 PM
both bases are the same only one has handles and the other doesn't...
the one w/ handles is for free hand routering and the other is for mounting in a table...
both operate and adjust identically..
you swap the motor from base to base to fit the need...
the 1617EVSPK has a handled base and a plunge base and you still get to swap the motor base to base as the need arises...
The plunge base will do everything the fixed base will do but not the other way around...
you can still mount the fixed base w/ handles from the PK kit in a table and if need be the handles are easily removable...
IMO, the 1617EVSPK is the better way to go and gives you a slight edge in versatility over the EVSTB version..
you can purchase a fixed base w/o the handles if you so desire seperately...
http://www.amazon.com/Bosch-RA1165-U.../dp/B0007VHPFK
post #3 of 17 (permalink) Old 02-07-2015, 10:56 PM Thread Starter
First Name: lee
So the fix based with wood handles adjusts from the top with the hex key the same as the router table version?
coxhaus is offline
post #4 of 17 (permalink) Old 02-07-2015, 11:03 PM
yes....
post #5 of 17 (permalink) Old 02-07-2015, 11:08 PM Thread Starter
First Name: lee
OK. I am back looking at the 1617EVSPK kit Lowes sells with the plunge base. Thanks for the info.
coxhaus is offline
post #6 of 17 (permalink) Old 02-08-2015, 07:30 AM
First Name: Ray
Hi Lee. What stick says is correct but you have to buy the lift separately. The Bosch routers do not have the lift feature built in to them like the Triton router does. Either Bosch router you mentioned ARE also router table versions. But if you are looking to adjust from the top with a hex key, you will need the separate lift that stick provided the link to in his post.
Also, you can save about $27 (taking taxes and shipping versus the two separate purchase methods into consideration) if you buy a factory reconditioned one here:
http://www.cpooutlets.com/factory-re...=5&q=1617EVSPK
Cheers!!!
~~Ray
Copyright©2015 A.D. (Anno Domini, Latin for "in the year of our Lord") e.g., historical FACT!
Life is a comedy for those who think, but a tragedy for those who feel.
Let your smile change the world. Don’t let the world change your smile.
RMIGHTY1 is offline
post #7 of 17 (permalink) Old 02-08-2015, 07:43 AM
Factory Reconditioned Bosch 1617EVSPK-RT 12 Amp 2.25 HP Combination Plunge and Fixed-Base Router Kit
Cheers!!!
~~Ray
Ray...
the fixed base is the lift...
post #8 of 17 (permalink) Old 02-08-2015, 09:19 AM
john60's Avatar
Shop Bosch 2.25-HP Variable Speed Corded Router at Lowes.com
The one at Lowes has the base for and tool for above table, The reconditioned one does not appear to have it
john60 is offline
post #9 of 17 (permalink) Old 02-08-2015, 09:27 AM
First Name: Ray
Ray...
Oh yes stick, I see now. They advertise:
"Now includes RA1161 fixed base with system for adjusting bit height from above a router table"
Sounds like a recent modification.
Sorry for steering you wrong Lee.
Thanks stick for the correction!
Cheers!!!
~~ Ray
RMIGHTY1 is offline
post #10 of 17 (permalink) Old 02-08-2015, 09:39 AM
First Name: Ray
You are right John, I see that now. The one at Lowes has the fixed base #RA1161 while the one at CPO has the fixed base #RA1160. The newer model at Lowes has the new feature: "Now includes RA1161 fixed base with system for adjusting bit height from above a router table"
I apologize again Lee for my misunderstanding. Was not aware of the upgrade. Am now.
Thanks John for the correction!
Cheers!!!
~~ Ray
RMIGHTY1 is offline
Hello with a router fence question nevertoosafe New Member Introductions 9 11-02-2014 03:22 PM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 07:43 PM
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 15 09-23-2014 09:15 AM
Bosch pof 1200 AE router question lplease.. thecoder General Routing 9 12-16-2013 05:29 AM
Bosch 2.25HP Plunge & Fixed Base Router Kit 1617EVSPK jcmaro General Routing 9 03-28-2009 09:12 PM
