Bosch 1617 EVS - Router Forums
post #1 of 16 (permalink) Old 02-08-2015, 08:30 AM Thread Starter
mjsb's Avatar
First Name: Michael
Default Bosch 1617 EVS
I've got a 1617 EVS that was dropped a while ago, the base cracked and has since been replaced. Recently while using it, the brushes on 1 side cracked, I replaced them and cleaned up the mess. Now I got nothing, no response to on and off. Any ideas on what the issue may be or how I may go about finding an answer?
mjsb is offline
post #2 of 16 (permalink) Old 02-08-2015, 08:32 AM
clean the commentator....
reseat the brushes...
post #3 of 16 (permalink) Old 02-08-2015, 09:36 AM
john60's Avatar
If you have an ohm meter check for resistance (router unplugged switch of) across the brushes. If the resistance is very high you have a brush contact problem or an armature problem.
john60 is offline
post #4 of 16 (permalink) Old 02-08-2015, 12:38 PM
"clean the commentator..."
I've often been tempted.
DaninVan is offline
post #5 of 16 (permalink) Old 02-08-2015, 02:47 PM
First Name: lee
What do you use to clean the commentator? I have used a pencil eraser to clean the copper plates on a commentator before. You have to be careful to clean out all the rubber pieces but I have never cleaned a router commentator.
coxhaus is offline
post #6 of 16 (permalink) Old 02-08-2015, 03:33 PM
I generally use a stiff brush and a Irish Spring...
Commutator (electric) - Wikipedia, the free encyclopedia
DaninVan is offline
post #7 of 16 (permalink) Old 02-08-2015, 05:24 PM
Nickp's Avatar
First Name: Nick
Stick..."illegitimi non carborundum"...
Nick
Nickp is online now
post #8 of 16 (permalink) Old 02-08-2015, 07:31 PM
jj777746's Avatar
Left yourself open for that one Stick,but we all knew what you meant
jj777746 is offline
post #9 of 16 (permalink) Old 02-08-2015, 10:33 PM
101 uses for Draino...
post #10 of 16 (permalink) Old 02-08-2015, 10:34 PM
eraser is fine...
Bosch 1617 EVS mounting plate ttromler Table-mounted Routing 1 04-10-2012 12:15 PM
Bosch EVS 1617 Adaptor to use PC accessories? kessler craftsman Guide Bushings and Templates 8 05-11-2011 10:35 PM
New member question about trouble with a Bosch 1617 EVS SD tinkerer New Member Introductions 5 09-26-2009 06:07 PM
Bosch 1617 EVS speed control problem pkunze New Member Introductions 4 07-11-2009 10:30 AM
Bosch 1617 EVS Sawdusty New Member Introductions 4 03-26-2008 07:25 AM
