Hitachi KM12VC Collet Stuck - Router Forums
post #1 of 29 (permalink) Old 02-16-2015, 08:34 PM Thread Starter
Default Hitachi KM12VC Collet Stuck
Hi All, I have run into a bit of an issue here and I am hoping someone can help!
I picked up a KM12VC router off CL a month or so ago, but just managed to find the free time to give it a test drive. Unfortunately I was unable to do such testing because I cannot get a bit into the router.
To the best of my descriptive ability I will say that it seems the 1/2" collet is stuck down in the collet sleeve making it impossible to fit a bit in the machine. Typically the collet would be towards the top of the sleeve and tighten down on the bit as the nut is tighten, but with the nut completely removed the collet is still stuck down there and I cannot figure out how to get it to loosen/raise/remove. Hopefully the way I have described this makes sense to someone?
User danngossman posted what I thought was a similar issue about a month ago but it seems his may have been slightly different and his solution involved a lot of leverage and a pair of pliers which may have now caused him more issues from what I was reading in his thread. I am hoping I dont have to go down the brut force issue as I really dont even see how that will fix it, but the manual doesnt go into enough detail to help with this type of thing so I am stuck.
Router genius' please help!
Chad
Chilton88 is offline
post #2 of 29 (permalink) Old 02-17-2015, 02:14 AM
Semipro's Avatar
First Name: John_*
Default Collet
Here is a picture of what you should have
The collet snaps into the nut I can not see inside well enough to tell if it is the right collet or not the reason you found it on CL is someone has jamed that collet into it
you will have to get it out and buy a new collet and nut 12 to 15 dollars
The shaft is tapered inside
Semipro is online now
post #3 of 29 (permalink) Old 02-17-2015, 08:51 AM Thread Starter
Thanks for the feedback Semipro! I thought this may be the issue when I saw the 1/4" collet that comes with the router, as it is still stuck in the nut, but I wasn't sure if they were both supposed to look that way...sounds like they are. I don't mind getting a new one as I got the router for pretty cheap, I honestly am just not sure how I am going to get the existing one out of the shaft?
post #4 of 29 (permalink) Old 02-17-2015, 09:17 AM
sometimes an easy out works....
another is draw/slide hammer if you can hook on to the bottom side of the collet...
soak the collet in a mix of acetone and ATF for a few hours 1st...
mix the acetone/ATF at a ratio of 1:1
post #5 of 29 (permalink) Old 02-17-2015, 09:43 AM
Semipro's Avatar
First Name: John_*
First you need to do this carefully no hammering
Do as Stick mentioned you may also cut a hole in a plastic bag to fit over shaft and tape it to keep junk out motor housing using a Dremel and small cutter carefully cut the top of collet above one of the slots
Thank You John
post #6 of 29 (permalink) Old 02-17-2015, 09:53 AM Thread Starter
Thank you for the advice Stick! I wish I could just remove the shaft and tap it out from the other side, would make my life much easier right now...
Excuse my ignorance but on the ATF/Acetone mix would I put the router, shaft downwards, and rest it in that or put that mix in the shaft? I would assume I would not want to put that in the shaft as I would think it could drain down into the motor and mess up other stuff but maybe it is sealed off and it is fine that way?
Thanks again Semipro, the Dremel option actually sounds like it might be the easiest since the pretty much all require a replacement collet in the end (with the exception of the slide hammer), I am just hoping the collet/nut will be the only needed replacement at the end of this adventure - thank you guys for all this help!
post #7 of 29 (permalink) Old 02-17-2015, 10:40 AM
dip the end of the shaft into a thimble of the solution...
you'll find that the shaft isn't hollow and only machined on the end to accept the collet.. at least it's that way on all of mine...
my 1st improvised slide hammer for this same job was nothing more than a cotter puller and a pair of pliers for the slide hammer... a few really easy repetitious taps w/ the pliers against the puller's handle was all it took... and I mean easy...
brute anything is not required....
key pullers... note the hook on the end...
FWIW... I didn't anchor or restrain the motor and it only took a couple three taps to ''get'er'' done...
if yours is ''that'' stuck... time for plan ''B''...
post #8 of 29 (permalink) Old 02-17-2015, 10:43 AM Thread Starter
You talked me into it You make it sound very easy so I'll give that a try before I start cutting away, how long does it need to be in the solution or is it just a dip?
Thanks again for the all ideas!
post #9 of 29 (permalink) Old 02-17-2015, 10:54 AM
once you get that collet removed consider it toast and you'll need to polish the inside of the inside of the shaft...
post #10 of 29 (permalink) Old 02-17-2015, 11:08 AM
this what I have now...
Bearing puller kits by SKF - Fast and easy bearing dismounting
Need help with broken collet and stuck bit on a brand new Hitachi M12VE. kracken41 General Routing 33 12-20-2012 07:27 PM
1/4" Collet for Hitachi M12V RzzB General Routing 53 07-26-2011 11:32 AM
Stuck collet on router - help tkm795 General Routing 5 01-13-2011 09:53 PM
Router Hitachi KM12VC Manual Manuals Hitachi Manuals 0 12-16-2010 01:30 AM
