Craftsman Router 31525070 parts - Router Forums
post #1 of 15 (permalink) Old 02-25-2015, 11:32 AM Thread Starter
First Name: ken
Default Craftsman Router 31525070 parts
Need parts for crafsman router 31525070. Locknut, part 1-623793-01, Jamnut, part 1-523794-02, they show to be MD. Thanks, Ken
kboyt is offline
post #2 of 15 (permalink) Old 02-25-2015, 06:58 PM
Hi Ken and welcome to the forum. The 315 in front of the model number me sans it's a Ryobi. If you can't get the parts from Sears I would suggest you take the machine to a repair shop with a good reputation and see if they have parts that will substitute for those. Otherwise it's new router time unless you find one for for parts.
post #3 of 15 (permalink) Old 02-25-2015, 07:12 PM
Welcome to the forum, Ken.
Unless you need to keep a very old router operating for some reason, I would look at replacing the router with an up to date variable speed router.
Sydney, Australia
jw2170 is offline
post #4 of 15 (permalink) Old 02-25-2015, 07:50 PM
old55's Avatar
First Name: Ross
Welcome to the forum Ken.
Ross,
old55 is offline
post #5 of 15 (permalink) Old 02-26-2015, 09:27 AM
BrianS's Avatar
First Name: Brian
Hi Ken. Welcome to our little corner of the 'net.
+1 on what others have said. If you find the part, great, but odds are against it. Sears regularly has routers for less than $200, cheaper when they are on sale. The current ones are a big improvement over the older models they sold.
Brian
(Origin uncertain)
BrianS is offline
post #6 of 15 (permalink) Old 02-26-2015, 11:17 AM
carl.p's Avatar
Country: South Africa
First Name: carl
Default welcome to the forum
Hi Ken welcome to the forum. carl
Classical music is food for the mind and soul.
carl.p is offline
post #7 of 15 (permalink) Old 02-26-2015, 10:47 PM
First Name: Rick (actually Enrico)
Default I might have what you need. Read details. Welcome
Ken, I have a dead 25070 that I am salvaging. I check the numbers you posted with the manual for my router, and the locknut is the same p/n as you listed, but the jamnut p/n in my manual is 1-623794-02 rather than the 1-523794-02 in your posting.
I assume that this is just a typo error in your note. Correct? Where did your number come from? A Sears 25070 manual?? In any case I need to figure out how to get the two nuts off, since it looks like flat wrenches are required that I may not have. If I can get them off the shaft, we can work out a deal to get them to you. You can contact me thru the Router Forum private messaging if you have the minimum number of posts to use it, or contact me at my e-mail [email protected]m.
Rick
jaguar1201 is offline
post #8 of 15 (permalink) Old 02-27-2015, 08:06 PM
Default Update on nut removal from my dead craftsman
Hi Ken,
I successfully removed the nuts from my dead Craftsman router that you may need, but I need info on how to get them to you. You can call me at 330 285 8296 from noon to 5 EST. The jamnut isn't really a nut because it has no threads, but just an internal key that engages a keyway in the shaft.
RICK CARUSO
post #9 of 15 (permalink) Old 03-02-2015, 10:17 AM Thread Starter
First Name: ken
Thanks Rick
And thanks to all for your help, I'm not a really big user of a router, but I'm trying to learn.
I rechecked the Craftsman and the keyway slot is damaged, I was using the router when the nuts exploded, few dents in shop wall, lucky that they were thrown away from me.
I ordered a new Dewalt dwp611pk.
Thanks Again for all the help.
Ken
kboyt is offline
post #10 of 15 (permalink) Old 03-02-2015, 03:33 PM
Default Failure analysis of craftsman router
Hi Ken, I am interested in more details on the Sears router that "exploded" the nuts.
Have you owned this router since it was new?
Did the armature shaft fracture also?
What knowledge can you provide as to what might have cause the nuts to fracture?
Can you provide photos of the nut pieces and the router shaft, especially the end where the nuts seat?
How was the router being used when the incident happened?
In my mechanical engineering career, I did supervise a team of engineers that was engaged in failure analysis of IC engines/parts and turbochargers, so I do nave considerable expertise in assigning cause of failure to machine parts. Also, since I use several of this model router, I am concerned for my own safety as well.
Best of luck with the new router.
Rick Caruso
Craftsman 315-17380 Router Parts feuerbak General Routing 15 07-02-2016 03:01 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Used router Missing Parts tkleff General Routing 3 02-13-2012 01:27 AM
opinions on Craftsman Professional router Sawatzky Table-mounted Routing 11 06-21-2010 08:34 PM
