Dremel Thread - Router Forums
post #1 of 6 (permalink) Old 02-27-2015, 09:20 AM Thread Starter
First Name: Gary
Default Dremel Thread
I would like to know if anyone could tell me the thread size on the end of a dremel rotary tool. I am speaking of the thread exposed after removing the cap at the end of the body. I want to make threads into a poly cutting board to attach the dremel.
gmercer_48083 is offline
post #2 of 6 (permalink) Old 02-27-2015, 10:09 AM
N'awlins77's Avatar
First Name: Lee
Gary, after doing a Google search, it's 3/4-12. I have one, and the tools to check myself, but thought it would be quicker to just Google that info. And unfortunately, the nominal size (sizes you will find at hardware stores) are 3/4-10 National Course or 3/4-16 National fine. So you will more and likely have to have a machine shop make you one that is 3/4-12. Not hard to do. Probably cost the minimum a shop charges in your area. I could probably have one made for around 50 bucks, here. If I had a lathe, I could even make one myself. ;o)
N'awlins77 is offline
post #3 of 6 (permalink) Old 02-27-2015, 11:57 AM
First Name: Andy
If Wikipedia is to be believed, the 3/4" size of British Standard Fine (BSF) thread is 12TPI. Apparently BSF thread taps are still available. Whether the thread form is sufficiently similar is another question of course.
AndyL is offline
post #4 of 6 (permalink) Old 02-27-2015, 11:26 PM
Honored Member
harrysin's Avatar
First Name: Harry
Another possibility and probably one that I would use in the absence of a suitable tap would be to rout a hole in the panel, square, round, it doesn't matter, also a rebate, similar to fitting a router table plate. Into the hole fit a metal plate, steel, brass, aluminium, whatever, and hold the the plate in the rebate with a small countersunk screw in each corner. The plate will have a 3/4" clearance hole and the Dremel poked through the hole and held in place with the housing cap. Problem solved!
Harry
harrysin is offline
post #5 of 6 (permalink) Old 02-28-2015, 07:40 AM
First Name: Roger
This Shop Dremel Rotary Cutting Kit at Lowes.com would give you a threaded collar that you might be able to use.
Do as you always do,,, Get what you always get
rcp612 is offline
post #6 of 6 (permalink) Old 02-28-2015, 07:49 AM Thread Starter
First Name: Gary
Thanks everyone!
Dremel (WeCheer) Ski belaire445 Jigs and Fixtures 8 07-12-2013 11:21 AM
How to start your own Workshop Thread. READ FIRST! Mark Workshop Showroom 0 04-03-2011 10:49 PM
Forum Rules and Usage - Read this before you post! Mark Wood Scrolling 0 08-26-2006 05:57 AM
Forum Rules and Usage - Read Before Posting Mark The Bargain Bin 0 01-14-2005 06:19 PM
