routing using a plunger - Router Forums
post #1 of 7 (permalink) Old 12-28-2004, 06:47 PM Thread Starter
Default routing using a plunger
what exactly is the reason for using a plunger versus not? what exactly is it for?
reds_21 is offline
post #2 of 7 (permalink) Old 12-28-2004, 07:47 PM
Bob N's Avatar
First Name: Bob
A plunge base allows you to come straight down into the wood with better control in beginning your cut. The fixed base must be leaned on it's side and "tipped" into the cut and can be tricky for beginners like me. I also prefer my fixed base for mounting to my table. Both bases have there value and purpose based on the person's skill and needs using it.
Bob N is offline
post #3 of 7 (permalink) Old 05-28-2014, 04:05 PM
rickjb's Avatar
Another situation where a plunge router works better is when using a Forstner bit to cut a recess into a piece of wood. The plunge router base will provide a true 90 degree angle relative to the wood surface and you can set the plunger stop for precise depth of cut. It worked for me very well - except I had to buy a collet for the 3/8 inch shank on my Forstner bits.
rickjb is offline
post #4 of 7 (permalink) Old 05-28-2014, 07:33 PM
Honored Member
First Name: pat
Some notes on selecting, whether table, trimmer, compact, plunger or fixed base.
Quillman is offline
post #5 of 7 (permalink) Old 05-29-2014, 07:42 AM
First Name: Duane
Rick, you should probably have a look at this page...
http://www.infinitytools.com/PDF/For...SpeedChart.pdf
Dmeadows is offline
post #6 of 7 (permalink) Old 05-29-2014, 08:07 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Forstner style bits were never intended for use in a router, only in a drill press.
One of my first posts after becoming a member of this forum and several times since was to wonder why America still mainly use fixed base routers when most of the world uses plunge routers which can do everything that a fixed base one can plus much, much more, plus they are MUCH SAFER, if a problem arises release pressure and the bit retracts into the safety of the body.
Harry
harrysin is offline
post #7 of 7 (permalink) Old 05-29-2014, 09:56 AM
rickjb's Avatar
Thanks Duane. Although I did not have that info at my side when I used my router with the Forstner bit, I did in fact slow down the machine considerably to prevent burning the bit.
Rick
rickjb is offline
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 09:12 PM
Freehand routing Visteonguy General Routing 53 07-12-2013 04:33 AM
wood residential and business sign routing with mark disaverio New Member Introductions 10 06-07-2013 11:55 PM
Dust Colection for routing Dados KentWW Table-mounted Routing 3 01-10-2007 02:18 PM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
