help with fliptop tool stand - Router Forums
post #1 of 4 (permalink) Old 02-27-2015, 02:51 PM Thread Starter
MT Born's Avatar
First Name: Dave
Default help with fliptop tool stand
I'm building a fliptop stand for my benchtop router and miter saw. The flip top portion is 3 pieces of 3/4 plywood material. This will rotate on a 1" piece of black pipe.
How should I rout the grove for the pipe?
Afraid I didn't think this through before I started.
Any assistance will be appreciated!
MT Born is offline
post #2 of 4 (permalink) Old 02-27-2015, 03:40 PM
MT Stringer's Avatar
When I built mine, I used two pieces of 5/8 inch alum rod. I cut the middle piece in two pieces and sandwiched the rods in between them. Then put the top piece on.
MT Stringer is online now
post #3 of 4 (permalink) Old 02-27-2015, 08:18 PM
If you were using 3/4" pope I would do the same as Mike. You only need an 1/8" groove in the top and bottom sheets and it won't need to be very wide. It also doesn't need to fit the curve of the pipe. The middle pieces jammed against it will hold it place. This doesn't need to be as complicated as I think you think it is.
post #4 of 4 (permalink) Old 03-01-2015, 03:12 AM
First Name: Gerry
I sandwiched a steel rod between two sheets of plywood. I made the channel for the rod by separating the sheets with two wood crosspieces the thickness of the rod. The outside edges of the sandwich were also supported by wooden pieces about 2 inches wide.
gkas is offline
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 03:33 PM
Craftsman v. Delta Tablesaws Thowie70 Tools and Woodworking 22 02-24-2014 10:12 PM
Peak HP dgcutter General Routing 22 01-10-2013 08:23 PM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-07-2012 11:17 PM
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 01:19 PM
