Lookin forSide adjust Lift for router - Router Forums
post #1 of 18 (permalink) Old 03-03-2015, 02:42 PM Thread Starter
GregLittleWoodworks's Avatar
First Name: Greg
Default Lookin forSide adjust Lift for router
I have seen several manufacturers come up with a table mounter router lift that allows height adjustments from the side instead from the top. Some are motorized and some are not. Most have disappeared and seem to be no longer available...and I would imagine that it is because they didn't work all that good.
MLCS, Woodpeck, Jessem and a couple of others I cannot remember.
I'm lookin for a good side adjust lift because when I do plunge routing with my router table I am currently limited by the approximate 3" distance from the bit to the insert position for the top mount lift tool.
Are yall aware of any new or available models that are out there?
The only one I have seen is a newer jessem setup that comes complete with a table top and mechanism built in...
As nice as it looks I am not spending that amount and I don't want to change from my Incra fence system
“Each step of every Wood Art project I design and build is considered my masterpiece… because I want the finished product to reflect the quality and creativeness of my work. I study each piece to get ideas and details that will evolve in my future creations.
GregLittleWoodworks is offline
post #2 of 18 (permalink) Old 03-03-2015, 03:33 PM
First Name: Ray
Hi Greg,
Dunno if this is what you are looking for:
Eagle America, Woodpeck still here:
Router Height Adjustment - Side Winder Router Lift
Just woodpeckers so far:
Woodpeckers’ Side Winder Router Lift - NewWoodworker.com LLC
Also:
http://www.eagleamerica.com/product/...ounting_plates
You prolly saw all these.
They seem to be a couple years old. Nothing new yet Greg, sorry
Copyright©2015 A.D. (Anno Domini, Latin for "in the year of our Lord") e.g., historical FACT!
Life is a comedy for those who think, but a tragedy for those who feel.
Let your smile change the world. Don’t let the world change your smile.
RMIGHTY1 is offline
post #3 of 18 (permalink) Old 03-03-2015, 04:20 PM
PhilBa's Avatar
First Name: phil
This one is a table, not just a lift
PhilBa is offline
post #4 of 18 (permalink) Old 03-03-2015, 04:36 PM
I have the JessEm...
no issues...
MAST-R-LIFT EXCEL II
post #5 of 18 (permalink) Old 03-03-2015, 06:28 PM Thread Starter
First Name: Greg
Originally Posted by RMIGHTY1 View Post
Hi Greg,
Also:
Mounting Plates & Lifts - "U-Turn" Router Lifts and Accessories
The woodpecker side model doesn't seem to be available any more...must of had some problems.
I need to look more into the MLCS one. There is only 1 review and I also want something that precisely fits my Incra table and fence system
post #6 of 18 (permalink) Old 03-03-2015, 06:33 PM Thread Starter
First Name: Greg
Phil...I saw that one and it is obviously well made but since it is a table also it won't be compatible with the Incra
post #7 of 18 (permalink) Old 03-03-2015, 06:36 PM Thread Starter
First Name: Greg
no issues...
Stick...the jessem is definitely quality but you gotta get their complete system. good for them but not good for me.
post #8 of 18 (permalink) Old 03-03-2015, 07:16 PM
how so...
all I and two others got was the lift and went from there...
I bought their top and realized that wasn't what I wanted so I went to a plastics distributer and found a drop piece of white 1" Carbon fiber reinforced polymer and then torsion boxed it...
the torsion box frame I made from 3/16 x 2 x 2" aluminum architectural channel...
post #9 of 18 (permalink) Old 03-03-2015, 08:48 PM
First Name: Earl
Over the past few days i've swapped a few messages with Al B Thayer, as i've just bought his lift plans (not sure when i'll do the build, but i'm going to try it). When i mentioned considering using a set of miter gears so i wouldn't have to move my Incra--Al pointed out that would likely introduce more lash than i'd probably want. That makes sense to me.
Since his design mounts vertically, my current (imcomplete) thought is to add a compartment inside my cabinet, so i can mount to the side instead of the back of the cabinet--and gain some bit storage at the same time. That would put my height adjustment in line with the bit.
Still, long term, i like the "sidewinder" thought. I don't think i like it $700 worth, but i like it!!
earl
greenacres2 is offline
post #10 of 18 (permalink) Old 03-04-2015, 02:43 AM
Have a look at the thread about the Hawk table and router. You could get a scissor jack for $5 from a junk yard. I've heard from several members that it works very well, just looks crappy.
My brand new router lift CR1 Table-mounted Routing 6 03-05-2013 01:22 AM
Router Lift Fusy Gepetto New Member Introductions 8 01-07-2013 08:06 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
PRL-V2 Router Lift DarkFlame Starting Off 8 03-20-2011 09:01 PM
Rousseau 3002 Router Lift LS 46_trap Table-mounted Routing 2 02-18-2008 08:59 PM
