Max power draw for Ryobi R163 ?? - Router Forums
 1Likes
post #1 of 32 (permalink) Old 03-11-2015, 05:10 PM Thread Starter
First Name: Bob
Question Max power draw for Ryobi R163 ??
Looking to determine if a household circuit rated at 700 W would be able to handle the load from working pine. The Ryobi manual doesn't show power ratings and the boilerplate on the router only says 8.5 A. Usually when power is not highlighted (as say in the DeWalt Table saw manual), it means it's not worth worrying about, but better safe than sorry, right?.
Anyways, does anybody know?
BobMcK is offline
post #2 of 32 (permalink) Old 03-11-2015, 05:23 PM
Semipro's Avatar
First Name: John_*
To answer this question you need know the voltage then you can calculate the current by dividing voltage into wattage. For example; an electric heater rated at 700 watts when plugged into a 115 v outlet will draw 700/115 = 6.08 amps of current
Semipro is offline
post #3 of 32 (permalink) Old 03-11-2015, 05:28 PM
Amps to Watts: Watts = Amps x Volts
8.5◊120 = 1020 watts
Watts to Amps: Amps = Watts / Volts
700ų120 = 5.83 amps...
house leg is too light weight...
where did you come up w/ 700 watt rating???
post #4 of 32 (permalink) Old 03-11-2015, 06:23 PM
The short answer is 'what else is on the cct?'
If it's a dedicated, or close to it cct, than you can run pretty much any I20V portable power tool off it...even with a 100' 12/3/1 extension cord plugged in.
If, on the other hand, you're running all the main floor lights off that cct., and they're all on, not going to happen.
Try it; if it's overloaded you'll pop the breaker...then you'll know for sure.
DaninVan is offline
post #5 of 32 (permalink) Old 03-11-2015, 06:47 PM
so what's a 12/3/1 cord???
post #6 of 32 (permalink) Old 03-11-2015, 07:50 PM
#12 , 3 conductor plus ground. Everybody leaves the "1" off when they say 12/3 but it's also available without ground...no green wire.
DaninVan is offline
post #7 of 32 (permalink) Old 03-11-2015, 07:55 PM
I can't believe this...
Wire & Cable | Wire | Southwire 63947655 Romex Cable with Ground, Yellow, 12/3 Awg, 250 ft | B242155 - GlobalIndustrial.ca
No identified ground wire?! Is Brown the new Green?!
And since when has the ground been called a "conductor"?!
DaninVan is offline
post #8 of 32 (permalink) Old 03-11-2015, 08:06 PM
so that makes for a 4 conductor cable...
what is the ''1'' designator in 12/3/1 suppose to mean???
12/3/WG???
post #9 of 32 (permalink) Old 03-11-2015, 09:31 PM
Yes.
Sorry, I can't find my Canadian Electrical Code...and I'm not buying a new one!
The Ground's either bare or Green.
Unless the Code's been changed I'm almost positive that the Ground is by definition not a conductor, and not all cable assemblies need a ground wire.
Here's a catalogue page as an example...
DaninVan is offline
post #10 of 32 (permalink) Old 03-11-2015, 09:31 PM
Sorry about the duplicated image...
DaninVan is offline
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 04:33 PM
Craftsman v. Delta Tablesaws Thowie70 Tools and Woodworking 22 02-24-2014 11:12 PM
Need Advise re Power Supply info for LED lighting gwizz Lobby 29 04-11-2013 09:44 PM
Peak HP dgcutter General Routing 22 01-10-2013 09:23 PM
All about Power Tools iconlife Tools and Woodworking 10 08-13-2012 01:09 PM
