How much CFM is Enough - Router Forums
 5Likes
post #1 of 11 (permalink) Old 03-13-2015, 03:43 PM Thread Starter
First Name: Tim
Default How much CFM is Enough
I have just finished making my new router table. I'm using a Triton 3 1/4 Hp TRA001 and I'm pulling the chips out with a Porter Cable Shop Vacuum. There are three pick up points. One is in the dust extraction port in the safety guard and two pick ups built into the fence on either side of the bit cove in the back. [Hope that's the right terminology?] The vacuum has a Dust Deputy keeping the filter clear, [which works great] so the vacuum seems to have a fair CFM as vacuums go. But still, it seems wanting in this capacity so my question is this. How much CFM should it have? How much CFM is Enough CFM?
Step 1 - Do. Step 2 Fail. Step 3 Learn. Step 4 Do Again.
Better
Alternative > Step 1 - Ask. Step 2 Do.
Teddytim1 is offline
post #2 of 11 (permalink) Old 03-13-2015, 03:55 PM
A shop vac has it's limits... they have suction but not CFM...
a little reading material for ya...
File Type: pdf Design and Build your own dust collection system.pdf (124.2 KB, 107 views)
File Type: pdf Dust Collection System Design 10 April 09.pdf (274.6 KB, 369 views)
timbertailor likes this.
post #3 of 11 (permalink) Old 03-13-2015, 06:10 PM
Nickp's Avatar
First Name: Nick
There's no replacement for cubic displacement...(racing days)
You'll know it's enough when the dust deputy gets overpowered and the sawdust circles round n round at its top...at that point you'll need a way to break the air flow. I usually turn the shop vac off and back on and the chips will drop. I am using a Ridgid 5 gal vac with the dust deputy...2 1/4" ID hose to the table and 1 1/2" ID to the vac. I'm guessing the dust deputy will keep doing its thing but I break the vacuum just in case...
Nick
Nick
Nickp is online now
post #4 of 11 (permalink) Old 03-13-2015, 08:02 PM
IMHO;
For a router, you should not need more that a shop vac. After all, if using correctly, you are only sucking up dust.
For a thickness planer or jointer, however you will be sucking up dust and chips...
Probably need about 1200cfm as a minimum..
I found that out the hard way....
BenAtar and jj777746 like this.
Sydney, Australia
jw2170 is offline
post #5 of 11 (permalink) Old 03-13-2015, 08:07 PM
pS, I would use a cyclone between the work and the vac....
Sydney, Australia
jw2170 is offline
post #6 of 11 (permalink) Old 03-14-2015, 08:08 AM
PhilBa's Avatar
First Name: phil
CFM depends on how much of an opening you have. If you use your hand to block the hose, you have zero CFM. For under router table DC most designs have a fresh air intake because you need to have flow. Suction doesn't move the chips, airflow does. So, if you have a 2.5" hose on your shop vac, you have about 5 square inches (4.9 actually) of opening, anything less on your table will reduce the airflow. Also, if you have too much of an opening, you will reduce the ability to pick up the chips. I like to think of it as balancing the flow though I'm sure there is some latitude. I'm wondering if the two fence ports are too much.
Most importantly, don't get too wound up about perfect DC. Give it a try and if it works for you, don't worry. If it doesn't tweak it until it works well enough.
For what it's worth, I use a 1.5 HP DC, 4" hose and a shop built Thein Baffle separator. I recently finished my router table top for PC7518 + Lift + Incra positioner. No RT cabinet yet (next project) so I built a shroud for under table DC. I left a good 6 sq inch opening in the shroud and use a fairly big insert in the lift plate. Amazingly good DC! The Incra LS doesn't have a dust port in the fence and I was concerned about that but it's really not necessary. I'll probably switch to the Incra inserts that have extra holes to improved my under table DC.
PhilBa is offline
post #7 of 11 (permalink) Old 03-14-2015, 04:22 PM
Ghidrah's Avatar
First Name: Ronald
A agree with James, I've been using the same old Craftsman 16 gal 6 hp wet/dry vac on the RT since 98. I used to use it on my TS too but I was filling up too fast so I went with the Delta DC 50-760 for the TS, jointer and BS. The Craftsman has enough suction to hold a piece of wood up to the fence and in place like it was glued.
If I draw from the bottom of the RT it does leave a little debris, but the cavity below the table 14"X14"X14" with a 1" X 14" suction slot at the bottom back. The only time I open the front is to change bits and lock the lift.
Ghidrah is offline
post #8 of 11 (permalink) Old 04-12-2015, 08:13 AM
Alf Beharie's Avatar
First Name: Alf
FWIW, you don't need to specifically buy a "Dust Deputy" Cyclone...Other makes of Cyclone are available that do exactly the same job but for considerably less money.
For instance, the "Dust Mite" Cyclone is half the price. I bought an "Omni Dust" version because it seems to be more robust than other makes...Cost £45...£25 cheaper than a Dust Deptuty!
Alf Beharie is offline
post #9 of 11 (permalink) Old 04-12-2015, 10:35 AM
RainMan 2.0's Avatar
I have a General dust collection unit and if I did it again I'd buy the biggest one available .
My theory now is to go with the biggest and baddest you can afford as you can have to little suction but I doubt you can have to much
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 11 (permalink) Old 04-12-2015, 02:38 PM
First Name: Brad
As PhilBa pointed out, CFM is generally limited to the diameter of the hose. 4" hose is about 400cfm. A 2hp unit will get you there if you only use it on one power tool at a time.
The real key is to upgrade the filters. Very few shop vacs or even the larger systems come with anything close to adequate to remove the extremely dangerous fine particles. You really want a filter that not only removes particles down to 0.5 micron, but also, able to supply a VERY high flow rate to prevent constant clogging.
Dust collection should not be thought of as a way to keep your shop clean.
It should be approached from a safety standpoint. Fine particles can severely affect you and your families health. So, the more flow, the better.
Stick provided some good links.
Here is another site I recommend spending some time getting familiar with.
Bill Pentz
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
How about a leaf blower based dust collection system? Chris Curl Tools and Woodworking 87 03-24-2017 12:54 AM
Do others do this (research)? > Dust Collection MAFoElffen Tools and Woodworking 61 08-27-2013 06:38 PM
Why a limit of dust collection points? TomB19 Tools and Woodworking 10 11-08-2012 08:20 AM
Air Compressor Help tiir22 Tools and Woodworking 19 08-21-2012 02:15 AM
Looking for good dust collecting BearLeeAlive Portable Routing 29 05-06-2010 07:52 PM
