Scrap piece test value - Router Forums
 2Likes
post #1 of 11 (permalink) Old 03-13-2015, 09:34 PM Thread Starter
jj777746's Avatar
Default Scrap piece test value
All set up for a simple "straighten a crooked line"on a 2ft 6in by 1ft 6in MDF panel when I thought I'd try a new bit. Clamped a 1x2inch at both ends to the panel & then decided to have a trial run on some scrap.Just as well I did because the bearing on this NEW bit flew off & put a groove in the scrap which would have ruined the panel.Not such a big deal but goes to show the value in doing a test routing with a new bit no matter how sharp & shiny it looks
jj777746 is online now
post #2 of 11 (permalink) Old 03-13-2015, 11:12 PM Thread Starter
jj777746's Avatar
Question Brand new bit
The bearing screw thread
was stripped
post #3 of 11 (permalink) Old 03-13-2015, 11:50 PM
was stripped
whose brand???
post #4 of 11 (permalink) Old 03-14-2015, 01:08 AM Thread Starter
jj777746's Avatar
whose brand???
Stick,Don't know what brand.It was in a small box of assorted 1/4in bits given to me as a gift & all painted blue. No name or marks found on box or bits. I wonder why.
post #5 of 11 (permalink) Old 03-14-2015, 06:13 AM
Duane Bledsoe's Avatar
First Name: Duane
Maybe Harbor Freight? They have dark blue bits.
Duane Bledsoe is offline
post #6 of 11 (permalink) Old 03-14-2015, 07:18 AM
Bushwhacker's Avatar
First Name: David
Could have been dangerous. I always test run a scrap piece, simply to check my set ups.
Bushwhacker is offline
post #7 of 11 (permalink) Old 03-14-2015, 08:59 AM
chessnut2's Avatar
Scary. Something I'll keep in mind from now on. Thanks. Jim
chessnut2 is offline
post #8 of 11 (permalink) Old 03-14-2015, 03:51 PM
I have had this happen to me twice. Both times it was with a Freud 1/2 in. flush trim bit. The first time was when I was using it to trim composite decking on my deck. Left a nice gouge in the deck, and I never did find the bearing. The second time it happened I got lucky and caught it before any significant damage. That time I found the bearing and the screw. Now I check the screw any time I use one of these bits, and periodically while I'm using it.
Tom B.
tbahorski is offline
post #9 of 11 (permalink) Old 03-14-2015, 03:55 PM
RainMan 2.0's Avatar
I'm going to remember this tip , thanks James
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 11 (permalink) Old 03-14-2015, 05:18 PM
Nickp's Avatar
First Name: Nick
Might a teeny weeny bit of Loctite Blue be good preventative maintenance...?
swarfmaker and jj777746 like this.
Nick
Nickp is offline
My first (test) freehand sign... jw2170 Sign Making 14 07-14-2014 09:06 AM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 05:01 PM
Cork Board (something from the scrap pile) Noddy Show N' Tell 6 09-07-2007 07:38 PM
Make a template to create a filler piece? Ric Naff Jigs and Fixtures 3 01-12-2006 08:56 PM
