Router collet replacement - Router Forums
post #1 of 10 (permalink) Old 11-10-2007, 01:16 PM Thread Starter
First Name: ray
Thumbs up Router collet replacement
I need to replace the collet on my ancient 3.2 amp Stanley Tool "Handyman" router. The model number is 039A. The existing collett has seized a 1\4 inch straight bit and refuses to release it. Any advice on where to get a replacement collett. Thank you. Raybo.
raybo is offline
post #2 of 10 (permalink) Old 11-10-2007, 01:29 PM
Hi raybo
That maybe a hard items to find
Try this get your heat gun out or hair dryer out and put some heat on the nut..
Then put the bit in some cold water but just the bit...then tap the bit out...use your cloves the nut must be HOT ....
Then WD40 the nut and clean it out with some steel wool...
Wood pitch can build up and lock the bit in place...
hope this helps
post #3 of 10 (permalink) Old 11-11-2007, 01:24 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the forums Raybo. Good luck with your collet.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 10 (permalink) Old 11-11-2007, 10:12 AM
Joe Lyddon's Avatar
First Name: Joe
Welcome!
Have Fun,
Joe
Alta Loma, CA
www.WoodworkStuff.net
Joe Lyddon is offline
post #5 of 10 (permalink) Old 11-11-2007, 01:55 PM
challagan's Avatar
Welcome Raybo to the forum!
corey
http://iowacarver.tripod.com/
challagan is offline
post #6 of 10 (permalink) Old 11-11-2007, 11:05 PM
Roefa's Avatar
First Name: Roger
Send a message via Yahoo to Roefa
Hi Rabo -
I'm not familiar with that particular router, but have "been there" with that problem. Be sure that the collet is not missing a snap ring. I had a Craftsman router with a collet like that. After I replaced the snap ring and then loosened the collet, the bit fell out easily. Good luck !
Roger
(Roefa)
Thinking outside the box? What box?
Roefa is offline
post #7 of 10 (permalink) Old 11-13-2007, 09:38 PM Thread Starter
First Name: ray
Originally Posted by bobj3
Hi raybo
hope this helps
Thank you for your reply. I like the bunch of polite, helpful, and warm replies that I received. I like this group already. Raybo.
raybo is offline
post #8 of 10 (permalink) Old 11-13-2007, 09:39 PM Thread Starter
First Name: ray
raybo is offline
post #9 of 10 (permalink) Old 11-13-2007, 09:43 PM Thread Starter
First Name: ray
Thank you for your reply. I like the bunch of polite, helpful, and warm replies that I received. I like this group already. I hope to use it more in the future, as I am building a router table designed by the "Router Lady" Carol reed" and it is coming along nicely. Raybo.
raybo is offline
post #10 of 10 (permalink) Old 11-13-2007, 11:23 PM
Hi Raybo , you'er welcome for my small part..
That will be a neat table, post a snapshot or two when you get it done..
http://www.shoptours.org/shop_tours/...arol-reed.html
http://www.woodcentral.com/shots/shot347.shtml
Some of the links work and some are dead, but some neat jigs. ▼
http://justwoodworking.com/links/jigs.php
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 08:01 AM
