Sketchup Help - Tablesaw Outfeed (T-Track) Table - Router Forums
 22Likes
post #1 of 19 (permalink) Old 03-19-2015, 03:35 PM Thread Starter
First Name: Nate
Default Sketchup Help - Tablesaw Outfeed (T-Track) Table
Hi - I am currently learning Sketchup - looking at all the great youtube videos and other tutorials that are out there on the web.
My current outfeed table is the standard Delta outfeed table that I bought about 15 years ago when I bought a Unisaw. It has started to sag and is very dinged up, so I want to build a new outfeed table.
I like the concept of the new Rockler T-Track table, so I would like to embed a T-track system on my outfeed table behind the saw.
I have attached a picture of the Rockler T-Track Table - for those that haven't seen one.
My table will be larger - about 48x65, with a T-Track Grid to allow me to clamp anywhere on the grid using the 5 or 6 existing Kreg clamps that I currently have. This will make things very flexible for clamping most anything.
MY SKETCHUP DRAWING
You can see that I have added 2 dados for the miter gauge tracks so that the tablesaw sled can move freely past the end of the saw.
I was able to place the 7 dados for the T-tracks that run the length (65") of the outfeed table and color them Rockler Blue.
You can see I have added Sketchup Guides for the T-tracks that run the width (48") of the table.
Now - here is my Sketchup issue.
When I tried to draw the rectangles and use the Push/Pull tool to create the 3/4" dados for the T-Track along the 48" direction, Sketchup wouldn't seem to allow me to make these dados "intersect" with the dados I had already drawn for the 65" direction. You can see I was able to create 6 short dados that intersect the 1st T-Track, but Sketchup seems to want to make me create all these short dados in the grid.
Seems like there should be a way to draw a grid of T-Tracks like I am envisioning?
Remember, that I am an EXTREME novice in Sketchup - this is my first real drawing, so if you reply, please be specific since I am a newbie.
Any help would be greatly appreciated - I am probably missing some little detail that would allow me to complete these T-track grids.
Sketchup gurus - feel free to look at my Sketchup drawing - maybe it would be easier for you to look at my drawing in your Sketchup and see what I might have done that would be causing this issue.
I have attached a .jpg of the Sketchup Drawing
I also attached the .zip file of the .skp file, since .skp is not an allowed file format.
Thanks Alot
Nate
Name:	Outfeed Table2.jpg
nsecrist is offline
post #2 of 19 (permalink) Old 03-19-2015, 03:59 PM
MT Stringer's Avatar
I don't think I can be of much help, Nate. I ran into the same problem. The push/pull tool stops at the intersection each time. Actually, I was doing the same thing today. Trying to lay out a design for a new top for my work bench/outfeed table/assy bench.
One thing I am worried about is boards coming off your saw and hanging up on any cross tracks. That would be especially true if the board was bowed down. I always try to make sure I rip them with any bow facing up, but you never know.
Here are a few pics of my current table with the Kreg Klamp Tracks. They work great.
Name:	2013-09-19 12.51.46.jpg
Name:	2015-01-08 16.20.56.jpg
Name:	2015-01-08 16.21.25.jpg
LT40sawyer and jj777746 like this.
MT Stringer is offline
post #3 of 19 (permalink) Old 03-19-2015, 04:48 PM
PhilBa's Avatar
First Name: phil
Yeah, when you drew the rectangles, they intersected with the other dados you drew and that cut your rectangle into a series of rectangles (and squares). You can go and push/pull each one.
There are a lot ways to do what you wanted but no really simple ones. You have to deal with those pesky intersections. One cute way is to draw one square and then use move/copy to make a row of them each separated by your dado width, then select the row and move/copy the row (to get a dado size separation again) to make a grid of squares. clean up the edges and then your dados can all be push/pulled at once.
Before you go and do all that work though, you might want to consider doing an MFT-like table like MT did. I'm about to embark on that. Love the idea of qwas dogs and such.
MT Stringer, jj777746 and Al_Breit like this.
PhilBa is offline
post #4 of 19 (permalink) Old 03-19-2015, 05:22 PM
Gaffboat's Avatar
First Name: Oliver
Here's how I do it, Nate. I draw the grooves/dados for the T-Track on the face of the table top. Then I erase the excess lines where they cross. Now I can simply select the area of the grooves/dados and use the push/pull tool to sink all of them into the face at one time. These images should help you see what I mean.
Another shortcut is to draw a long groove once and then use the move tool to copy and move it to the next location.
Name:	Erase lines.png
Gaffboat is offline
post #5 of 19 (permalink) Old 03-19-2015, 05:26 PM Thread Starter
First Name: Nate
Default Thanks Oliver for the Tip!
Oliver - what you have shown looks like it will be the easiest overall.
Thank you for the illustration! That really helps.
nsecrist is offline
post #6 of 19 (permalink) Old 03-19-2015, 06:14 PM
I played with your drawing for a bit.
I made a couple of changes. I measured a piece of t track and it is 3/8 inch deep, so I changed all dadoes to 3/8 inch x 3/4. I left the miter gauge dadoes as is.
I like rounded corners so I replaced your edge trim with new stuff and rounded the corners.
And I cut clamp access in the trim so the clamps can be moved from one track to another.
As you learn, learn to make layers to help you work on the model. That way you can use Entity Info to assign parts of your drawing to various layers. Then you can turn em on or off. Helps to get in tight places when something is in the way.
And then there is my mobile workstation. This thing is the cat's meow. All sorts of clamping possibilities with dog holes and slots for f style clamps.
And you can see I put it to work before I had purchased the Formica for the top. Check out them rounded corners!
Name:	Nates table top1.jpg
Name:	Nates table top2.jpg
Name:	2014-01-05 21.33.46.jpg
Name:	2013-11-23 15.50.23.jpg
Name:	2013-11-23 15.54.41.jpg
RMIGHTY1 and LT40sawyer like this.
post #7 of 19 (permalink) Old 03-19-2015, 06:23 PM
First Name: Earl
I'd echo Mike's concerns about the tracks running across the outfeed direction being a potential problem. Looks like you're tracks are about 6" apart--so stock would never be more than 3" from a track--and always in reach of a clamp. I could see the cross tracks being handy at times for assembly--but not enough to risk catching the outfeed stock from my table saw on. Your mileage may vary.
earl
MT Stringer likes this.
greenacres2 is offline
post #8 of 19 (permalink) Old 03-19-2015, 10:16 PM
Just by coincidence, I was drawing a new table for my work bench today. Nothing definite yet, but a possibility. Overall size is 31 1/2 inches x 49 1/2 inches.
I might have to build this during this coming year.
post #9 of 19 (permalink) Old 03-20-2015, 12:43 AM
vindaloo's Avatar
First Name: Angie
Mike, if you made it deeper, and used individual blocks to support the top you could add a dust extraction port and have a downdraft sanding table.
vindaloo is offline
post #10 of 19 (permalink) Old 03-20-2015, 07:49 AM
MEBCWD's Avatar
earl
I would have the out feed top lower than the saw table and have a panel to cover the t-track top with cutouts for the miter bar extension.
MEBCWD is offline
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
New Router Table flemingj1122 Table-mounted Routing 13 05-19-2012 03:02 PM
3 in 1 Heavy duty Tablesaw, Router Table, Drum Sander hubert_gut Tools and Woodworking 1 03-04-2012 08:47 AM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 09:15 PM
