Linear bearings - Router Forums
 1Likes
  • 1 Post By harrysin
post #1 of 6 (permalink) Old 03-29-2015, 05:52 AM Thread Starter
First Name: Paul
Default Linear bearings
Hi just wondered if any one had every made any planing sleds using linear bearings .
Was wondering if it would work on a xz axis type setup. Any pictures or suggestions.
Many thanks
apw joinery is offline
post #2 of 6 (permalink) Old 03-29-2015, 08:11 AM
PhilBa's Avatar
First Name: phil
Haven't done that but it should work as long as you have fairly heavy duty rails.
That said, it seems like overkill. A smooth, waxed surface for the router to slide on seems good enough.
PhilBa is offline
post #3 of 6 (permalink) Old 03-29-2015, 10:06 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Many thanks
My experience is that some friction is best, it prevents the router attempting to go it's own way. These shots showing the ski mounted router being used for planing with the end cheeks on the chipboard sacrificial table. The last shots show my attempt to reduce the friction by adding roller balls, it was a disaster!
Tagwatts1 likes this.
Harry
harrysin is offline
post #4 of 6 (permalink) Old 03-29-2015, 10:34 AM
Welcome to the forum Paul. I think Harry is probably right about having a little resistance. I haven't used skis but I did need to build a very large sled to level my 2.4m long workbench and sliding effort wasn't an issue.
post #5 of 6 (permalink) Old 03-29-2015, 06:32 PM
old55's Avatar
First Name: Ross
Ross,
old55 is offline
post #6 of 6 (permalink) Old 05-19-2015, 10:34 AM
phillipsted's Avatar
First Name: Ted
I've been fiddling with building a planing sled setup for a couple of months now. I use mitre slot rails on the sides and 10mm rods and linear bearings for the crossbars to support the router. I found that with too much resistance, I was pushing the router out of "plumb" by pushing too hard to move it.
I've been meaning to post some pics, but wanted to work out the kinks first. Soon.
BTW, there are lots of really good parts on ebay for this - linear bearings, guide rods and pillow blocks. You'll want at least a 10mm diameter rod, but could go up to 20mm for extra rigidity.
TedP
phillipsted is offline
linear bearing dust issue Abid CNC Routing 11 05-12-2014 04:43 AM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
Babbit bearings Jack Wilson Lobby 3 04-09-2011 09:27 PM
How are the bearings in your router mike black General Routing 8 04-12-2010 10:03 PM
