part needed - Router Forums
 2Likes
post #1 of 14 (permalink) Old 04-07-2015, 09:13 PM Thread Starter
First Name: miles
Default part needed
Hi everyone. I have a Sears router model number 31517380 that has a broken cable that runs from the trigger to the switch in the motor housing. According to the diagram it's #65 part number 2-606580-01. It's a great running router and I hate to discard it plus it belonged to my dad and has sentimental value also. Any help would be much appreciated. Miles
VS Jeff likes this.
mr miles is offline
post #2 of 14 (permalink) Old 04-08-2015, 12:12 AM
Hi Miles and welcome to the forum. There may be a couple of options. One is to bypass the switch and use a remote switch instead. Another possibility may be stainless steel braided fishing line if you need to make a cable a certain length. It has a breaking strength of 400 lbs and you use crimpable ferrules to make loops at the ends.
post #3 of 14 (permalink) Old 04-08-2015, 07:23 AM
Nickp's Avatar
First Name: Nick
+1 on making a new wire...
Possibilities include thin stainless binding wire or Monel which will allow you to bend the ends around the trigger and still be flexible enough. It probably needs to be stiff enough so that it does not allow too much slack when you pull the trigger.
If the broken cable is twisted wire, try something like picture hanging wire, again stainless.
You could solder the ends accordingly to keep it neat.
Good luck...
Nick
Nickp is offline
post #4 of 14 (permalink) Old 04-08-2015, 07:28 AM
First Name: del
Good luck...
i don't belive you can solder to stainless wire , i belive picture hanging wire can be eather just wire or stainless
del schisler
port st. lucie, florida
del schisler is offline
post #5 of 14 (permalink) Old 04-08-2015, 07:57 AM
First Name: Art
I would by pass the switch and hook it up to a cheap speed controller like a $15 dollar Harbor Freight one.
RainMan 2.0 likes this.
mgmine is offline
post #6 of 14 (permalink) Old 04-08-2015, 11:15 AM
Nickp's Avatar
First Name: Nick
Thanks, Del...the steel must be very clean and slight surface abrasion helps adhering. Convential heating devices can be used with acid-based flux and 50/50 tin/silver solder wire. Tinning the ends will help a lot. Even heating is important.
My first choice would be to make a new cable with thin wire and formed ends.
Stripped right sized copper twisted wire would work also. The ends could be solder tinned for forming instead of twisting...
The idea is to use stiff enough wire so the action does not create slack in the cable housing which would curtail the trigger travel and possibly not actuate the switch.
You are correct...soldering stainless is not easy...
Thanks again for pointing out the need for more explanation...
If Miles wants to bypass the switch I would use a foot switch for handheld operation; this would mimick the hand switch...maybe...
Nick
Nickp is offline
post #7 of 14 (permalink) Old 04-08-2015, 09:23 PM Thread Starter
First Name: miles
Thank you guys for all the helpful tips. It's overwhelming. I had considered trying to replace the cable but wasn't real sure what to use since the original wasn't available anymore. The original was stranded. I do have some solid stainless steel wire but not sure if it will work. There is one thing I wanted to add. After the cable passes through the the trigger it goes through a spring and then runs through a small feral with a screw in the side of it that holds the cable. I presume I'll still need to leave the spring in place once the new cable in installed otherwise the trigger won't work properly. Let me know if I'm wrong about this. Miles
mr miles is offline
post #8 of 14 (permalink) Old 04-09-2015, 01:36 AM
Agreed. I wouldn't change anything that doesn't have to be.
post #9 of 14 (permalink) Old 04-09-2015, 06:25 AM
Nickp's Avatar
First Name: Nick
The spring is necessary in order to help releasing the trigger. Without it the switch and trigger could stick in the on position.
Stainless is harder to work with so if you do use it, form/bend the ends (solid wire) to attach to the trigger and switch lever.
Stranded wire might need ends formed in some manner as to attach (knot, twist, ferrule,etc)...it depends on how much room you have.
Pictures will help and likely to get you more ideas from other members.
Nick
Nickp is offline
post #10 of 14 (permalink) Old 04-10-2015, 04:38 AM
old55's Avatar
First Name: Ross
Welcome to the forum Miles.
Ross,
old55 is online now
Need Craftsman Jointer Part gromit Tools and Woodworking 5 12-10-2012 11:57 AM
Making a male part for a female part Chris Curl Guide Bushings and Templates 28 12-10-2012 08:08 AM
Routing smaller boards EnRouteWoodcrafts Portable Routing 17 10-25-2012 09:37 AM
Handle needed DOXIN General Routing 4 08-02-2010 04:42 AM
Part needed! johnpaulh General Routing 3 05-04-2009 05:06 AM
