Router Speed - Router Forums
post #1 of 5 (permalink) Old 12-14-2007, 06:30 PM Thread Starter
First Name: George
Default Router Speed
Let's talk router speed. Ok I am learning and starting to feel more confortable with my routers. What speed is recomended for various woods?
TIA
George II
George Cole
George II is offline
post #2 of 5 (permalink) Old 12-14-2007, 07:03 PM
Hamlin's Avatar
First Name: Ken
Speeds should be set per the size of bit. Ie., if you're turning a 3" bit, you want a slow speed.
I'm sure others will chime in and give better explainations than I.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 5 (permalink) Old 12-14-2007, 07:39 PM
You will get a cleaner cut running at a higher speed. Here is a speed chart to assist you in deciding the proper speed. Your router has a voice, if it doesn't sound right something is wrong.
File Type: pdf Suggested Maximum Router Bit Speeds.pdf (33.8 KB, 331 views)
post #4 of 5 (permalink) Old 12-14-2007, 07:47 PM
Hi George two
Read the link below, it will give you the suggested speeds..
http://www.routerworkshop.com/routerbits.html
But I must say I don't agree with all of them...
I run my router on the # 2 speed setting most of the time, I know speed kills and speed = heat...so to speak in a cutting tool.. .
To me it's like running a car eng.full out no need, it will get you from a to b without wiping the eng. out...and I also know the people that make the routers and the bits want you to keep on buying them and the only way to do that is for you to wipe them out with heat or speed...
Just need to think about just a bit 10,000 to 15,000 rpm's is FAST..for any cutting tool without any lub on it..and it will heat up quick..and once the bit gets to the Blue HOT point it's done cutting..and becomes a file in a way..the sharp edge is gone...
If you take a hard look at a router bit the cutting edge is a VERY small part of the bit..Very small part but it must be sharp in order to do a good job, no real way to keep the bit cool other than take some of the speed down to keep the heat down..doing so will make the bits last longer and the router too..
Hope this helps, and it just my 2 cents...
TIA
George Cole
post #5 of 5 (permalink) Old 12-14-2007, 08:13 PM Thread Starter
First Name: George
Hamlin, Bob and Mike,
Thanks alot..Tomorrow it is sneak out of the house get to the shop lock the door and make wood chips...You guys are the greatest.
Regards,
George Cole
George II
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
